Security and compliance
Configure security contexts for UiPath services in Automation Suite to meet compliance and least-privilege requirements.
Security context for UiPath® services
This section provides details on the security context of the UiPath® services.
All UiPath® services are configured with a security context defined in their spec section.
The following sample shows a typical configuration for UiPath® services:
spec:
  securityContext:
    runAsNonRoot: true
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
  containers:
    - securityContext:
        allowPrivilegeEscalation: false
        readOnlyRootFilesystem: true
        capabilities:
          drop: ["ALL"]
  hostPID: false
  hostNetwork: false
spec:
  securityContext:
    runAsNonRoot: true
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
  containers:
    - securityContext:
        capabilities:
          drop: ["ALL"]
  hostPID: false
  hostNetwork: false
In some instances, the user IDs and group IDs can be greater than or equal to 1000, depending on your environment. Make sure you configure the user and group IDs according to your security principles and your organization's security guidelines.
Pod security standards
Automation Suite uses the following AdmissionConfiguration to enforce pod security settings:
apiVersion: apiserver.config.k8s.io/v1
kind: AdmissionConfiguration
plugins:
- name: PodSecurity
  configuration:
    apiVersion: pod-security.admission.config.k8s.io/v1beta1
    kind: PodSecurityConfiguration
    defaults:
      enforce: "privileged"
      enforce-version: "latest"
    exemptions:
      usernames: []
      runtimeClasses: []
      namespaces: []
plugins:
- name: PodSecurity
  configuration:
    defaults:
    exemptions:
      usernames: []
      runtimeClasses: []
      namespaces: []
Automation Suite cannot use a stricter RKE2 CIS profile because of its dependency on Istio, which violates enforce: baseline standards. For the complete policy list, refer to Pod Security Standards.
Enabling FIPS 140-2
Federal Information Processing Standards 140-2 (FIPS 140-2) is a security standard that validates the effectiveness of cryptographic modules.
You can enable FIPS 140-2 on the machines on which you install Automation Suite in the following scenarios:
  1. Enable FIPS 140-2 before performing a clean installation of Automation Suite 2023.4 or later. For details, refer to Enabling FIPS 140-2 for new installations.
  2. Enable FIPS 140-2 after performing an Automation Suite installation on a machine with FIPS-140-2 disabled. For details, refer to Enabling FIPS 140-2 for existing installations.
Note:
The fips-mode-setup tool has been removed starting with RHEL 10. RHEL 10 requires FIPS mode to be enabled during OS installation. Switching to FIPS mode after installation is not supported in RHEL 10.
To enable FIPS 140-2 on the machines where you plan to perform a fresh installation of Automation Suite, take the following steps:
  1. Before starting the Automation Suite installation, enable FIPS 140-2 on your machines. For details, refer to Enabling FIPS 140-2.
  2. Perform the Automation Suite installation by following the installation instructions in this guide.
    Note:
    • If you install AI Center on a FIPS 140-2-enabled machine and also use Microsoft SQL Server, some additional configuration is required. For details, refer to SQL requirements for AI Center.
    • Make sure Insights is disabled, as it is not supported on FIPS 140-2. If you need to use Insights, you can deploy it on a dedicated non-FIPS node. For details, refer to How to deploy Insights in a FIPS-enabled cluster.
  3. Set the fips_enabled_nodes flag to true in the cluster_config.json file.
  4. Make sure your certificates are FIPS 140-2-compatible.
    Note:
    By default, Automation Suite generates self-signed FIPS 140-2-compatible certificates whose expiry date depends on the type of Automation Suite installation you choose. We strongly recommend that you replace these self-signed certificates with CA-issued certificates at installation time. To use Automation Suite on FIPS 140-2-enabled machines, the newly provided certificates must be FIPS 140-2-compatible. For a list of eligible ciphers supported by RHEL, refer to the RHEL documentation.
    • To update the token-signing certificates, run:
      ./bin/uipathctl config token-signing-certificates update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey
    • To update the TLS certificates, run:
      ./bin/uipathctl config additional-ca-certificates update --ca-cert-file /path/to/ca/certs
You can install Automation Suite with FIPS 140-2 disabled, and then enable the security standard on the same machines. This is also possible when you upgrade to a new Automation Suite version.
To enable FIPS 140-2 on the machines where you already performed an Automation Suite installation, take the following steps:
  1. Perform a regular Automation Suite installation or upgrade operation on machines with FIPS 140-2 disabled.
  2. Enable FIPS 140-2 by running the following command on all your machines:
    fips-mode-setup --enable
  3. Make sure your certificates are FIPS 140-2-compatible.
    Note:
    To use Automation Suite on FIPS 140-2-enabled machines, you must replace your certificates with new FIPS 140-2-compatible certificates signed by a CA. For a list of eligible ciphers supported by RHEL, refer to RHEL documentation.
    For more on certificates, refer to Managing the certificates.
  4. Make sure your product selection is in line with the FIPS-140-2 requirements:
    • If you previously enabled Insights, you must disable it as it is not supported on FIPS 140-2. If you need to use Insights, you can deploy it on a dedicated non-FIPS node. For details, refer to How to deploy Insights in a FIPS-enabled cluster. For details on how to disable products post-installation, refer to Managing products.
  5. Reboot your machines and check if you successfully enabled FIPS 140-2.
    fips-mode-setup --check
  6. Rerun the uipathctl installer:
    • In an online environment, run:
      ./bin/uipathctl rke2 install -i cluster_config.json -o output.json -s --accept-license-agreement - Online -- online
    • In an offline environment, run:
      ./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -s --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
