- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Load balancer requirements and configuration options for multi-node HA-ready production deployments in Automation Suite.
A load balancer is mandatory for the multi-node HA-ready production setup.
Some load balancers, such as the Azure Load Balancer, have the capability to forward the client's IP address to the server without replacing it with their own address. This feature allows the server to see the original client's IP, resulting in no extra steps being required for the server to identify the client's IP address.
On the other hand, if a load balancer does replace the client IP address with its own, it can compensate by adding a special header, called an x-forwarded-for header to the request it sends to the server. This header includes the original client's IP address. The server can then read this header to retrieve the client's IP address.
Automation Suite supports two types of configuration for the load balancer, as shown in the following sections.
You can configure the load balancer to use session persistence or sticky sessions, but it is not a requirement.
Currently, Automation Suite supports Layer 4 (network layer) load balancers. Layer 7 (application layer) load balancers are also supported. For details, refer to Configuring the L7 Load Balancer (Optional).
The load balancer does not support TLS encryption and termination. For effective service operation, make sure to configure your load balancer to facilitate traffic pass-through.
If you are using the Azure Internal Load Balancer (LB) for deployments, you can encounter issues with the calls from the backend Virtual Machine (VM) to the LB frontend IP. The issues occur due to source IP and MAC address mismatch of the network packet.
This prevents the recipient from working out the correct response path, resulting in the failure of calls from the VM to the LB. For more details, refer to Azure Load Balancer Components limitations and Backend Traffic Troubleshooting.
Server and node pool configuration
This is the recommended configuration for the load balancer.
Configuring the backend pool
You must create three backend pools that meet the following requirements:
- Server Pool
- Consists of all the server nodes.
- There must not be any agent nodes in the Server Pool.
- Node Pool
- Consists of all the server nodes and non-specialized agent nodes. Specialized agent nodes include
gpu, andasrobots.
- Temporary Registry Pool
- Consists only of the server node where the Temporary Registry is installed.
Note:The Temporary Registry Pool is used only during the Automation Suite installation, node joining, and upgrade procedures. After you complete the procedures, you can close the Temporary Registry Pool.
Configuring the health probes
The following table describes the health probe configuration for the load balancer.
| Probe | Protocol | Port | Interval | Re-entry threshold | Associate pool |
https-probe | TCP | 443 | 15 sec | 2 | Node Pool |
kubeapi-probe | TCP | 6443 | 15 sec | 2 | Server Pool |
Refer to the following illustration for details on the configuration:
Enabling ports on the load balancer
Ensure you have the following ports enabled on your firewall for the source of load balancer:
| Port | Protocol | Purpose | Traffic forwarding | Health probe |
443 | TCP | For HTTPS (accessing Automation Suite). | Traffic on this port must be forwarded to Node Pool. | https-probe |
300701 | TCP | For accessing the temporary registry during installation and upgrade using HTTP. | Traffic on this port must be forwarded to the Temporary Registry Pool. | N/A |
6443 | TCP | For accessing Kube API using HTTPS; required for node joining. | Traffic on this port should be forwarded to Server Pool. | kubeapi-probe |
9345 | TCP | For accessing Kube API using HTTPS; required for node joining. | Traffic on this port should be forwarded to Server Pool. | kubeapi-probe |
1 If you do not have an external OCI-complaint registry, you must open port 30070 on the load balancer and the server node on which you plan to install the temporary docker registry.
We recommend not exposing any ports except for the HTTPS one outside the cluster. Run your nodes behind a firewall / security group.
If you have a firewall set up on the network, make sure that it has these ports open to allow traffic.
The regular load balancer configuration should be similar to the one shown in the following illustration:
Alternative configuration
This configuration does not have resilience to nodes going down during installation.
If the primary server is down or deleted, cluster configuration needs to be updated.
FQDN of the primary server needs to be remapped to a different machine in the cluster that is available.
Create one backend Pool, as follows:
- Create a Node Pool
Ensure that you have the following ports enabled on your firewall for the source of load balancer:
443 | TCP | For HTTPS (accessing Automation Suite). | Traffic on this port should be forwarded to the Node Pool. |
Refer to the following illustration for details on the configuration.
