- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Restore hidden etcd data and correct the Rancher and etcd disk mount order after a reboot on Automation Suite on Linux.
On multi-disk installations, the dedicated etcd disk, mounted at /var/lib/rancher/rke2/server/db, must be mounted after its parent directory, /var/lib/rancher. If the mount order is reversed, so that /var/lib/rancher gets mounted on top of an already-mounted etcd disk, the etcd data becomes hidden underneath the /var/lib/rancher mount.
A reboot that re-triggers this incorrect mount order makes the RKE2 server node appear to lose all persistent volumes, persistent volume claims, and applications, even though the underlying etcd data is still present on disk.
Starting with Automation Suite 2.2510.4, the uipathctl rke2 prereq run command checks for this condition. To run the check, use the following command:
./bin/uipathctl rke2 prereq run cluster_config.json --versions ./versions/helm-charts.json --log-level=debug --included disk --node-type server -v
If the mount order is incorrect, the check fails with the following error:
❌ [RKE2_DISK]
❌ [Rancher_Etcd_Mount_Order] '/var/lib/rancher/rke2/server/db' is not mounted. Configure the cluster disk (--cluster-disk-name) before continuing, or if both disks are already mounted, do the data migration if required, unmount and remount (or reboot) so '/var/lib/rancher' is mounted before '/var/lib/rancher/rke2/server/db'.
❌ [RKE2_DISK]
On earlier versions, or if you prefer not to run the full prereq check, verify the mount order directly:
stat -c '%n -> %D' /var/lib/rancher/ /var/lib/rancher/rke2/server/db /
If the device IDs are not all different, the etcd disk is not mounted at its expected path.
Solution
For a multi-node cluster, apply the following steps to one server node at a time, and confirm the node is healthy before moving to the next node. Back up the cluster and put it in maintenance mode before you begin. Run all commands as root (sudo -i).
To fix the mount order and restore the hidden etcd data, take the following steps:
Stop the node drain and RKE2 server services, then unmount both paths:
systemctl stop node-drain.service systemctl stop rke2-server rke2-killall.sh umount /var/lib/rancher umount /var/lib/rancher/rke2/server/dbsystemctl stop node-drain.service systemctl stop rke2-server rke2-killall.sh umount /var/lib/rancher umount /var/lib/rancher/rke2/server/db -
Mount the parent
/var/lib/ranchervolume only:RANCHER_UUID=$(blkid -o value -s UUID /dev/uipathvg/rancherlv) mount -t xfs -o defaults,nofail UUID="$RANCHER_UUID" /var/lib/rancherRANCHER_UUID=$(blkid -o value -s UUID /dev/uipathvg/rancherlv) mount -t xfs -o defaults,nofail UUID="$RANCHER_UUID" /var/lib/rancher -
Mount the etcd disk to a temporary location, so the hidden data is exposed instead of being covered again:
mkdir -p /mnt/tmp_db ETCD_UUID=$(blkid -o value -s UUID /dev/uipathetcdvg/etcdlv) mount -t xfs -o defaults,nofail UUID="$ETCD_UUID" /mnt/tmp_dbmkdir -p /mnt/tmp_db ETCD_UUID=$(blkid -o value -s UUID /dev/uipathetcdvg/etcdlv) mount -t xfs -o defaults,nofail UUID="$ETCD_UUID" /mnt/tmp_db -
Copy the hidden etcd data to the etcd disk:
cp -ax /var/lib/rancher/rke2/server/db/. /mnt/tmp_db/cp -ax /var/lib/rancher/rke2/server/db/. /mnt/tmp_db/ -
Unmount the temporary location, clear the stale data from the parent disk, and mount the etcd disk at its correct nested path:
umount /mnt/tmp_db rmdir /mnt/tmp_db find /var/lib/rancher/rke2/server/db -mindepth 1 -delete mount -t xfs -o defaults,nofail UUID="$ETCD_UUID" /var/lib/rancher/rke2/server/dbumount /mnt/tmp_db rmdir /mnt/tmp_db find /var/lib/rancher/rke2/server/db -mindepth 1 -delete mount -t xfs -o defaults,nofail UUID="$ETCD_UUID" /var/lib/rancher/rke2/server/db -
Update
/etc/fstabso the mount order persists across reboots. The parent mount (/var/lib/rancher) must be declared before the nested mount (/var/lib/rancher/rke2/server/db):# uipath-rancher UUID=<rancher-disk-uuid> /var/lib/rancher xfs defaults,nofail 0 0 # uipath-etcd UUID=<etcd-disk-uuid> /var/lib/rancher/rke2/server/db xfs defaults,nofail 0 0# uipath-rancher UUID=<rancher-disk-uuid> /var/lib/rancher xfs defaults,nofail 0 0 # uipath-etcd UUID=<etcd-disk-uuid> /var/lib/rancher/rke2/server/db xfs defaults,nofail 0 0Before rebooting, verify that both paths mount correctly:
mountpoint /var/lib/rancher mountpoint /var/lib/rancher/rke2/server/dbmountpoint /var/lib/rancher mountpoint /var/lib/rancher/rke2/server/db -
Verify the mount order and restart the cluster services:
df -h | grep rancher systemctl start rke2-server systemctl start node-uncordondf -h | grep rancher systemctl start rke2-server systemctl start node-uncordon
