Adding a Dedicated Agent Node for Automation Suite Robots
Add a dedicated agent node for Automation Suite Robots to separate robot workloads from other cluster services.
Requirements
Before starting the Automation Suite Robot installation, make sure you meet the hardware requirements.
  • In a single-node evaluation installation, Automation Suite Robots run on the main server node. Cached packages are stored on the main node's filesystem, in a folder that the interactive installer automatically provisions. Adding a dedicated agent node for Automation Suite Robots is optional in single-node evaluation installations.
    Note:
    In a single-node evaluation installation, the number of concurrent serverless jobs is limited to 5.
  • In a multi-node HA-ready production environment, adding a dedicated node for Automation Suite Robots is mandatory. For details on the requirements the dedicated node must meet, refer to Hardware and software requirements.
    Note:
    In a multi-node HA-ready production installation, the maximum number of concurrent serverless jobs is determined by the node's resources (CPU/memory).
  • A minimum of 10GB are required for package caching.
Adding an Automation Suite Agent Node to the Cluster
The following sections provide instructions on how to add a dedicated agent node for Automation Suite Robots.
Step 1: Configuring the Machine
Step 1.1: Partitioning the disk
To ensure the disk is partitioned correctly, refer to Configuring the disks. Make sure to follow the steps for agent nodes.
Step 1.2: Configuring the disk for package caching
Option A
If you enabled package caching during installation, you must provision a folder on the filesystem of the host machine at the /uipath_asrobots_package_cache location or at the custom path configured via cluster_config.json/packagecachefolder. The folder must have at least 10GB of free space available, otherwise the installation will fail.
Option B
Alternatively, you can provision a separate disk to the configureUiPathDisks script, which can configure the disk and the path:
./bin/uipathctl rke2 disk --robot-package-disk-name [DISKNAME] --robot-package-path /uipath_asrobots_package_cache
Note:
The --robot-package-path parameter is optional. If not set, the parameter defaults to /uipath_asrobots_package_cache. If you modify the default value of cluster_config.json/packagecachefolder, make sure the value passed to the --robot-package-path parameter matches the configured value.
Step 1.3: Configuring the node for serverless robots
When configuring a node for serverless robots, the setup depends on how the node is added to the cluster:
Option A: Add a dedicated ASR node
If you add a new node to the cluster as a dedicated ASR node, the required labels and taints are automatically applied. Run the following command:
./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -k -j asrobots --accept-license-agreement
The command automatically adds the following:
  • taint: serverless.robot=present:NoSchedule
  • labels: serverless.robot=true and serverless.daemon=true
Option B: Use an existing agent node
If you want to repurpose an already configured agent node (not configured by default as ASR), you must manually add the labels, taints, and configure the package cache disk. Run the following commands to configure the node manually:
  1. Add a taint for serverless robots:
    kubectl taint nodes [NODE_NAME] serverless.robot=present:NoSchedule
  2. Add the labels for serverless robots:
    kubectl label nodes [NODE_NAME] serverless.robot=true serverless.daemon=true
Step 2: Copying the Interactive Installer to the Target Machine
To copy the interactive installer to the target machine, take the following steps:
  1. SSH to the right machine:
    • If you added Automation Suite Robots to a single-node evaluation installation, go to the main machine.
    • If you added Automation Suite Robots to a multi-node HA-ready production installation, go to any of the server nodes.
  2. Copy the contents of the UiPathAutomationSuite folder to the Automation Suite Robots node. Make sure to use the username and DNS specific to the Automation Suite Robots node.
    sudo su -
    scp -r /opt/UiPathAutomationSuite <username>@<node dns>:/opt/
    scp -r ~/* <username>@<node dns>:/opt/UiPathAutomationSuite/
    sudo su -
Step 3: Running the Interactive Installer to Configure the Dedicated Node
To configure the dedicated node, take the following steps:
  1. SSH to the Automation Suite Robots node.
  2. Run the Automation Suite interactive installer.
    sudo su -
    cd /opt/UiPathAutomationSuite
    yum install unzip jq -y
    CONFIG_PATH=/opt/UiPathAutomationSuite/cluster_config.json
    sudo su -
Step 4: Enabling Kubectl
To set the kubectl context on the Automation Suite Robots machine, run the following command:
sudo su -
export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodes
sudo su -
kubectl get nodes
You should see the nodes and their corresponding names. You need the name of the Automation Suite Robots node for the next step.
Step 5: Verifying the Automation Suite Robots Configuration
Check if the Automation Suite Robots node is configured. Make sure to replace <node name> with the Automation Suite Robots node name.
kubectl describe node <node name> | grep -i "taints"
The command should return the following output:
$ kubectl describe node asrobots0 | grep -i "taints"
Taints:             serverless.robot=present:NoSchedule
At this point, you have successfully completed the installation for Automation Suite Robots.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
