Disaster recovery - Installing the secondary cluster
Install the secondary Automation Suite cluster for disaster recovery Active/Passive or Active/Active deployments.
To install the secondary Automation Suite cluster in an Active/Passive or Active/Active deployment, take the following steps.
  1. Generate or copy the cluster_config.json file from the primary Automation Suite cluster to one of the nodes identified as the server in the secondary Automation Suite cluster. For details, refer to Generating or copying the configuration file of the primary cluster.
  2. Update the cluster_config.json file with the parameters specific to the secondary Automation Suite cluster.
  3. Resume the Automation Suite installation.
  4. Switch off inactive products if you use an Active/Passive configuration.
Generate a new cluster_config.json file or copy it from the primary cluster.
  1. Log into any server node and become root:
    ssh <username>@<machine_ip>
    sudo su -
    export PATH=$PATH:/var/lib/rancher/rke2/bin
    export KUBECONFIG=/etc/rancher/rke2/rke2.yaml
    sudo su -
  2. Generate the cluster_config.json file if you do not have one:
    ./bin/uipathctl manifest get-revision >> /path/to/new/cluster_config.json
  3. Copy the cluster_config.json file to a server nodes in the secondary cluster:
    scp /path/to/new/cluster_config.json <username>@<primary_machine_ip>:<username>@<secondary_machine_ip>
Updating the configuration file
Update the cluster_config.json file with the parameters specific to the secondary Automation Suite cluster by taking the following steps:
  1. Turn off the unsupported products.
    Set all the products that are not supported in multi-site to false.
    • For an Active/Passive configuration, disable the products that do not support Active/Passive. For details on Active/Passive support at product level, refer to the table in Disaster recovery - Active/Passive. The following example shows how to disable products:
        "test_manager": {
          "enabled": false
        "process_mining": {
          "enabled": false
        "automation_hub": {
          "enabled": false
        "insights": {
          "enabled": false
        "test_manager": {
          "enabled": false
        "process_mining": {
          "enabled": false
        "automation_hub": {
          "enabled": false
        "insights": {
          "enabled": false
    Note:
    Make sure that you enable the platform service as shown in the following example:
    "platform": {
    "enabled": true
    "platform": {
    "enabled": true
  2. Generate the kubeconfig of the primary cluster. This is required to access a few of the configurations by the secondary cluster made on the primary cluster. To get the kubeconfig file with the limited permission related to disaster recovery, run the following command:
    ./bin/uipathctl config kubeconfig get --multisite
    Copy the value provided in the command output. This value is required in the next step.
  3. Generate a new GUID for rke_token to prevent the secondary cluster from joining the primary cluster. To do that, run the following command:
    LC_CTYPE=C tr </dev/urandom -dc '!@#$%q_A-Z-a-z-0-9' | head -c 16
Resume the installation
Once the parameters in the previous step are provided or modified in the cluster_config.json, you can resume the installation. For details, refer to Installing Automation Suite.
Note:
You must perform the Automation Suite installation using the uipathctl installer. Note that you do not need to generate a new cluster_config.json.
Switching off inactive products
Important:
This step is required. Skipping it may cause some services to fail. This step is not required if you opt for an Active/Active setup.
If you deployed Automation Suite in Active/Passive mode, switch off the inactive products using the following command.
./bin/uipathctl cluster maintenance enable
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
