Installation packages download links
Download links and instructions for obtaining Automation Suite installation, upgrade, and diagnostic packages and scripts for online and offline deployments.
PackagePurpose
as-installer.zipUsed for installation, upgrade, cluster restore, and adding new nodes.
as.tar.gzUsed for installation and upgrade.
uipathctlUsed for diagnostics and troubleshooting.
du-ondemand.tar.gzUsed for Document Understanding installation.
dumodernexperience.tar.gzUsed for Document Understanding modern projects installation.
cv-ondemand.tar.gzUsed for Computer Vision installation.
mirror-registry.shUsed for installation and configuration when using an external OCI-compliant registry.
hydrate-registry.shUsed for installation and configuration when using an external OCI-compliant registry.
as-images.txtUsed for installation and configuration when using an external OCI-compliant registry.
as-helm-charts.txtUsed for installation and configuration when using an external OCI-compliant registry.
as-fs.tar.gzUsed for installation and configuration when using a temporary registry.
versions.jsonUsed for prerequisite checks and installation.
rke2-killall.shForcefully stops all RKE2-related processes on a node, including services and the container runtime. Used for maintenance, troubleshooting, or before uninstallation.
Tip:
This page provides instructions on downloading the files to the current directory of the current user. If you want to change the directory, make sure to provide the path to download using the -O parameter.
as-installer.zip
as-installer.zip is an installation package that contains the main installation and supporting scripts. The package also contains the uipathctl tool.
Note:
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
If you choose the offline installation profile, you must download as-installer.zip. If you opt for the online installation profile, as-installer.zip is automatically downloaded by the interactive installation wizard.
The as-installer.zip file is required during installation, upgrade, cluster restore in the event of disaster, and while adding new node to existing cluster.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/installer-2.2510.3.zip
  • Linux:
    To download as-installer.zip on a Linux machine, run the following command from the terminal:
    wget -O as-installer.zip https://download.uipath.com/automation-suite/2.2510.3/installer-2.2510.3.zip
  • Windows:
    On a Windows machine, open the URL in your browser to download the file, then rename it to as-installer.zip.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/installer-2.2510.2.zip
  • Linux:
    wget -O as-installer.zip https://download.uipath.com/automation-suite/2.2510.2/installer-2.2510.2.zip
  • Windows:
    On a Windows machine, download installer-2.2510.2.zip and rename it to as-installer.zip.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/installer-2.2510.1.zip
  • Linux:
    wget -O as-installer.zip https://download.uipath.com/automation-suite/2.2510.1/installer-2.2510.1.zip
  • Windows:
    On a Windows machine, download installer-2.2510.1.zip and rename it to as-installer.zip.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/installer-2.2510.0.zip
  • Linux:
    wget -O as-installer.zip https://download.uipath.com/automation-suite/2.2510.0/installer-2.2510.0.zip
  • Windows:
    On a Windows machine, download installer-2.2510.0.zip and rename it to as-installer.zip.
uipathctl
Required. uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite. You can use uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
Note:
2.2510.3
To download uipathctl for Automation Suite 2.2510.3, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-darwin-amd64.tar.gz
2.2510.2
To download uipathctl for Automation Suite 2.2510.2, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-darwin-amd64.tar.gz
2.2510.1
To download uipathctl for Automation Suite 2.2510.1, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-darwin-amd64.tar.gz
2.2510.0
To download uipathctl for Automation Suite 2.2510.0, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-darwin-amd64.tar.gz
Full as.tar.gz
as.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product. The bundle is approximately 30 GB in size.
The full as.tar.gz is ideal for users with strong network connections who wish to download the complete file in one go.
If you opt for the offline installation profile, you must download as.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly from the container registry hosted in UiPath® servers.
as.tar.gz is required during installation and upgrade only on server node when using internal Docker registry.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-sha256sum.txt
  • Linux:
    To download as.tar.gz on a Linux machine, run the following command from the terminal:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3.tar.gz
  • Windows:
    On a Windows machine, open the URL in your browser to download the file, then rename it to as.tar.gz.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2.tar.gz
For the checksum file, download as-2.2510.2-sha256sum.txt.
  • Linux:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2.tar.gz
  • Windows:
    On a Windows machine, download as-2.2510.2.tar.gz and rename it to as.tar.gz.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1.tar.gz
For the checksum file, download as-2.2510.1-sha256sum.txt.
  • Linux:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1.tar.gz
  • Windows:
    On a Windows machine, download as-2.2510.1.tar.gz and rename it to as.tar.gz.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0.tar.gz
For the checksum file, download as-2.2510.0-sha256sum.txt.
  • Linux:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0.tar.gz
  • Windows:
    On a Windows machine, download as-2.2510.0.tar.gz and rename it to as.tar.gz.
Split as.tar.gz
The split as.tar.gz is designed for users with restricted networks, or those who may encounter challenges when downloading larger files.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-001
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-002
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-003
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-004
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-005
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-006
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-007
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-008
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-009
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-010
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-011
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-012
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-013
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-014
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-015
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-016
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-017
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-018
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-019
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-020
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-021
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-022
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-023
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-024
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-025
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-026
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-027
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-028
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-029
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-030
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-031
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-032
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-033
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-034
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-035
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-036
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-037
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-038
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-039
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-040
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-041
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-042
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-043
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-044
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-045
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-046
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-047
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-048
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-049
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-050
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-051
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-052
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-053
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-054
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-055
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-056
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-057
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-058
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-059
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-060
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-061
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-062
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-063
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-064
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-065
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-066
https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-067
  • Linux:
    To download each split file on a Linux machine, you can use the wget command. The command to download the first part is provided here:
    wget https://download.uipath.com/automation-suite/2.2510.3/as-2.2510.3-part-001
    Repeat this process for each subsequent part by incrementing the part number in the file name.
    After downloading all parts, run the following command to concatenate the parts into a single as.tar.gz file:
    cat as-2.2510.3-part-* > as.tar.gz
  • Windows:
    Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the full as.tar.gz file.
    After downloading all parts, run the following command via Command Prompt to concatenate the parts into a single as.tar.gz file:
    copy /b as-2.2510.3-part-* as.tar.gz
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-001
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-002
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-003
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-004
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-005
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-006
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-007
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-008
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-009
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-010
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-011
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-012
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-013
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-014
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-015
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-016
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-017
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-018
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-019
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-020
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-021
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-022
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-023
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-024
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-025
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-026
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-027
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-028
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-029
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-030
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-031
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-032
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-033
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-034
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-035
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-036
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-037
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-038
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-039
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-040
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-041
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-042
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-043
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-044
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-045
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-046
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-047
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-048
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-049
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-050
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-051
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-052
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-053
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-054
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-055
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-056
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-057
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-058
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-059
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-060
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-061
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-062
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-063
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-064
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-065
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-066
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-067
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-068
https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-069
  • Linux:
    wget https://download.uipath.com/automation-suite/2.2510.2/as-2.2510.2-part-001
    cat as-2.2510.2-part-* > as.tar.gz
  • Windows:
    copy /b as-2.2510.2-part-* as.tar.gz
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-001
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-002
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-003
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-004
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-005
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-006
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-007
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-008
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-009
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-010
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-011
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-012
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-013
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-014
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-015
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-016
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-017
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-018
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-019
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-020
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-021
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-022
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-023
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-024
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-025
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-026
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-027
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-028
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-029
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-030
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-031
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-032
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-033
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-034
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-035
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-036
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-037
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-038
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-039
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-040
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-041
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-042
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-043
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-044
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-045
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-046
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-047
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-048
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-049
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-050
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-051
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-052
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-053
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-054
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-055
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-056
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-057
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-058
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-059
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-060
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-061
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-062
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-063
https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-064
  • Linux:
    wget https://download.uipath.com/automation-suite/2.2510.1/as-2.2510.1-part-001
    cat as-2.2510.1-part-* > as.tar.gz
  • Windows:
    copy /b as-2.2510.1-part-* as.tar.gz
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-001
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-002
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-003
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-004
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-005
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-006
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-007
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-008
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-009
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-010
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-011
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-012
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-013
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-014
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-015
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-016
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-017
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-018
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-019
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-020
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-021
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-022
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-023
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-024
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-025
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-026
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-027
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-028
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-029
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-030
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-031
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-032
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-033
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-034
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-035
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-036
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-037
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-038
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-039
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-040
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-041
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-042
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-043
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-044
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-045
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-046
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-047
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-048
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-049
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-050
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-051
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-052
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-053
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-054
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-055
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-056
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-057
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-058
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-059
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-060
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-061
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-062
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-063
https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-064
  • Linux:
    wget https://download.uipath.com/automation-suite/2.2510.0/as-2.2510.0-part-001
    cat as-2.2510.0-part-* > as.tar.gz
  • Windows:
    copy /b as-2.2510.0-part-* as.tar.gz
du-ondemand.tar.gz
du-ondemand.tar.gz contains base images to install Document Understanding packages.
If you opt for the offline installation profile, you need to download du-ondemand.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly from the container registry hosted in UiPath® servers.
du-ondemand.tar.gz is required only when Document Understanding is installed.
For download instructions, refer to ML Packages Offline Installation.
Important:
After downloading Document Understanding packages, make sure to rename them to du-ondemand.tar.gz.
dumodernexperience.tar.gz contains the Document Understanding modern projects bundle.
If you opt for the offline installation profile, you need to download dumodernexperience.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly from the container registry hosted in UiPath® servers.
dumodernexperience.tar.gz is required only when Document Understanding modern projects is installed.
cv-ondemand.tar.gz
cv-ondemand.tar.gz contains Computer Vision models and packages.
If you opt for the offline installation profile, you must download cv-ondemand.tar.gz. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the container registry hosted in UiPath® servers.
cv-ondemand.tar.gz is required only when you want to use Computer Vision models.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3-sha256sum.txt
  • Linux:
    To download cv-ondemand.tar.gz on a Linux machine, run the following command from the terminal:
    wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3.tar.gz
  • Windows:
    On a Windows machine, open the URL in your browser to download the file, then rename it to cv-ondemand.tar.gz.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/cv2510-2.2510.2.tar.gz
For the checksum file, download cv2510-2.2510.2-sha256sum.txt.
  • Linux:
    wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.2/cv2510-2.2510.2.tar.gz
  • Windows:
    On a Windows machine, download cv2510-2.2510.2.tar.gz and rename it to cv-ondemand.tar.gz.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/cv2510-2.2510.1.tar.gz
For the checksum file, download cv2510-2.2510.1-sha256sum.txt.
  • Linux:
    wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.1/cv2510-2.2510.1.tar.gz
  • Windows:
    On a Windows machine, download cv2510-2.2510.1.tar.gz and rename it to cv-ondemand.tar.gz.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gz
For the checksum file, download cv2510-2.2510.0-sha256sum.txt.
  • Linux:
    wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gz
  • Windows:
    On a Windows machine, download cv2510-2.2510.0.tar.gz and rename it to cv-ondemand.tar.gz.
uipathtools
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands. The tool is backward compatible and works with any supported Automation Suite version. We recommend using uipathtools as the first step if you face any issue.
2.2510.3
To download uipathtools, run one of the following commands, depending on your OS:
  • Linux:
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-linux-amd64.tar.gz
  • Windows:
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-windows-amd64.tar.gz
  • macOS:
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-darwin-amd64.tar.gz
2.2510.2
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-windows-amd64.tar.gz
  • macOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-darwin-amd64.tar.gz
2.2510.1
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-windows-amd64.tar.gz
  • macOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-darwin-amd64.tar.gz
2.2510.0
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-windows-amd64.tar.gz
  • macOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-darwin-amd64.tar.gz
mirror-registry.sh
mirror-registry.sh is required to configure an external Docker registry.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/mirror-registry.sh
  • Linux:
    To download mirror-registry.sh on a Linux machine, run the following command from the terminal:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.3/mirror-registry.sh
  • Windows:
    On a Windows machine, open the URL in your browser to download the file.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/mirror-registry.sh
  • Linux:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2/mirror-registry.sh
  • Windows:
    On a Windows machine, download mirror-registry.sh.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/mirror-registry.sh
  • Linux:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.1/mirror-registry.sh
  • Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/mirror-registry.sh
  • Linux:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0/mirror-registry.sh
  • Windows:
hydrate-registry.sh
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/hydrate-registry.sh
  • Linux:
    To download hydrate-registry.sh on a Linux machine, run the following command from the terminal:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.3/hydrate-registry.sh
  • Windows:
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/hydrate-registry.sh
  • Linux:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2/hydrate-registry.sh
  • Windows:
    On a Windows machine, download hydrate-registry.sh.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/hydrate-registry.sh
  • Linux:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.1/hydrate-registry.sh
  • Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/hydrate-registry.sh
  • Linux:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0/hydrate-registry.sh
  • Windows:
as-images.txt
as-images.txt contains the name and version of the container images that must be pulled and uploaded into the external Docker registry.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/embedded-images.txt
  • Linux:
    To download embedded-images.txt on a Linux machine, run the following command from the terminal:
    wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.3/embedded-images.txt
  • Windows:
    On a Windows machine, open the URL in your browser to download the file, then rename it to as-images.txt.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/embedded-images.txt
  • Linux:
    wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.2/embedded-images.txt
  • Windows:
    On a Windows machine, download embedded-images.txt and rename it to as-images.txt.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/embedded-images.txt
  • Linux:
    wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.1/embedded-images.txt
  • Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/embedded-images.txt
  • Linux:
    wget -O as-images.txt https://download.uipath.com/automation-suite/2.2510.0/embedded-images.txt
  • Windows:
as-helm-charts.txt
as-helm-charts.txt contain the details for the UiPath® application helm chart that must be pulled and uploaded to an external Docker registry hosted on your environment.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/embedded-helm-charts.txt
  • Linux:
    To download embedded-helm-charts.txt on a Linux machine, run the following command from the terminal:
    wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.3/embedded-helm-charts.txt
  • Windows:
    On a Windows machine, open the URL in your browser to download the file, then rename it to as-helm-charts.txt.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/embedded-helm-charts.txt
  • Linux:
    wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2/embedded-helm-charts.txt
  • Windows:
    On a Windows machine, download embedded-helm-charts.txt and rename it to as-helm-charts.txt.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/embedded-helm-charts.txt
  • Linux:
    wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.1/embedded-helm-charts.txt
  • Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/embedded-helm-charts.txt
  • Linux:
    wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0/embedded-helm-charts.txt
  • Windows:
as-fs.tar.gz
as-fs.tar.gz contains the Helm charts and images to deploy the shared components and the service components in offline mode.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/as-fs-2.2510.3.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.3/as-fs-2.2510.3-sha256sum.txt
  • Linux:
    To download as-fs.tar.gz on a Linux machine, run the following command from the terminal:
    wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.3/as-fs-2.2510.3.tar.gz
  • Windows:
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/as-fs-2.2510.2.tar.gz
For the checksum file, download as-fs-2.2510.2-sha256sum.txt.
  • Linux:
    wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.2/as-fs-2.2510.2.tar.gz
  • Windows:
    On a Windows machine, download as-fs-2.2510.2.tar.gz.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/as-fs-2.2510.1.tar.gz
For the checksum file, download as-fs-2.2510.1-sha256sum.txt.
  • Linux:
    wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.1/as-fs-2.2510.1.tar.gz
  • Windows:
    On a Windows machine, download as-fs-2.2510.1.tar.gz.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/as-fs-2.2510.0.tar.gz
For the checksum file, download as-fs-2.2510.0-sha256sum.txt.
  • Linux:
    wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2.2510.0/as-fs-2.2510.0.tar.gz
  • Windows:
    On a Windows machine, download as-fs-2.2510.0.tar.gz.
versions.json
Needed to perform prerequisite checks and installation steps.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/versions.json
  • Linux:
    To download versions.json on a Linux machine, run the following command from the terminal:
    wget -O versions.json https://download.uipath.com/automation-suite/2.2510.3/versions.json
  • Windows:
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/versions.json
  • Linux:
    wget -O versions.json https://download.uipath.com/automation-suite/2.2510.2/versions.json
  • Windows:
    On a Windows machine, download versions.json.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/versions.json
  • Linux:
    wget -O versions.json https://download.uipath.com/automation-suite/2.2510.1/versions.json
  • Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/versions.json
  • Linux:
    wget -O versions.json https://download.uipath.com/automation-suite/2.2510.0/versions.json
  • Windows:
rke2-killall.sh
To download rke2-killall.sh on a Linux machine, run the following command from the terminal:
wget -O /usr/bin/rke2-killall.sh  https://raw.githubusercontent.com/UiPath/automation-suite-support-tools/refs/heads/main/Scripts/GeneralTools/rke2-killall.sh
chmod +x /usr/bin/rke2-killall.sh
Make sure to store the file in the following location:/usr/bin/rke2-killall.sh.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
