- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for generating the cluster_config.json file manually or with the Installer Wizard for Automation Suite deployments.
Generating cluster_config.json on the first machine
The cluster_config.json file defines the parameters, settings, and preferences applied to the UiPath® products deployed via Automation Suite.
You can generate the cluster_config.json configuration file either manually or using the Automation Suite Installer Wizard. While the wizard offers a more user-friendly approach, it currently does not accommodate all possible configuration scenarios.
In some specific instances, manual creation of the configuration file might be required. For details, refer to Configuring cluster_config.json.
You can always edit the generated file to update the configuration.
Generating the configuration file using a wizard
To generate cluster_config.json using the Automation Suite Installer Wizard, take the following steps:
Launch the wizard on port 80 on the local host by running the following command:
On Linux/macOS:
./uipathctl config generate./uipathctl config generate -
On Windows:
./uipathctl.exe config generate./uipathctl.exe config generate
To launch the wizard on a different port and host, run the following command:
On Linux/macOS:
./uipathctl config generate --port <your port> --host <your IP address>./uipathctl config generate --port <your port> --host <your IP address> -
On Windows:
./uipathctl.exe config generate --port <your port> --host <your IP address>./uipathctl.exe config generate --port <your port> --host <your IP address>
In a browser of your choice, launch the wizard by accessing the following URL:
http://localhost:80.If you chose a different host and port, make sure to replace
localhostand80with the IP address and port where you want to launch the wizard. -
Accept the license agreement.
Indicate the platform where you want to host Automation Suite. You can choose from the following options:
Automation Suite on AKS
Automation Suite on EKS
Automation Suite on OpenShift
Automation Suite on Linux
Note:The instructions in this guide are applicable if you choose this option.
Specify your deployment mode. You can choose from the following options:
- Online - Choose this option to install Automation Suite in an online environment. This deployment mode requires internet access during installation and runtime.
- Offline - Choose this option to install Automation in an offline environment. This deployment mode requires an OCI-compliant container registry.
For details, refer to Online deployment or Offline deployment.
Indicate your deployment type. You can choose from the following options:
- Highly Available - Choose this option if you want to install Automation Suite in multi-node HA-ready mode.
- Lite mode - Choose this option if you want to install Automation Suite in lite mode.
For details, refer to Deployment modes and use cases.
Provide additional details on your initial configuration. Depending on your previous selection, you may have to provide details such as the Automation Suite FQDN, admin username and password, storage class, namespace, ArgoCD project, and ArgoCD application namespace.
Indicate the Automation Suite products you want to enable.
For details, refer to Automation Suite products.
Provide the details on your SQL database configuration, such as the following:
- Whether you want to bring your own database or you want the Automation Suite installer to create it for you
- Whether you want to use Kerberos authentication
- The Redis cache details
For details, refer to Configuring SQL databases.
Specify the storage configuration details, such as storage type or bucket details.
For details, refer to Hardware requirements.
If you opted for an offline installation, provide the details of your OCI-compliant registry.
For details, refer to Configuring the OCI-compliant registry.
Provide your certificates details.
For details, refer to Certificates.
Specify the products for which you want to perform advanced configuration such as overwrite platform-level configurations with service-level configurations such as connections strings, objectstore setup, etc.
Download the
cluster_config.jsonconfiguration file.
Any feature that is not available during the cluster_config.json configuration using the Automation Suite Installer Wizard, can be manually included after downloading the configuration file.
Copying cluster_config.json to all the other machines
To install Automation Suite, the cluster_config.json file must be available on all the machines. After generating the configuration file on the first machine, you must copy it to the other machines instead of regenerating it. Regenerating the configuration file may result in discrepancies that could cause the installation to fail.
To copy the configuration file from the first machine to the other machines, run the following command. Make sure to replace username and node_dns with the values relevant to the target machine.
scp /opt/UiPathAutomationSuite/cluster_config.json <username>@<node_dns>:/opt/UiPathAutomationSuite
If you do not have direct access to copy the files to the /opt/UiPathAutomationSuite folder, you can transfer them to your home directory, and then move them to the desired location.
