Running uipathctl
Learn how to run uipathctl, the UiPath command-line tool for managing operations in Automation Suite deployments.
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS, Automation Suite on OpenShift, and Automation Suite on Linux.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
You can install uipathctl on the Linux, macOS, and Windows platforms.
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
For details, including a complete list of uipathctl operations, refer to the uipathctl Reference Guide.
Running uipathctl on Linux
To run uipathctl on Linux, take the following steps:
  1. Download the version of the uipathctl binary that you are interested in. For instructions, refer to Downloading the installation packages.
  2. Uncompress uipathctl and add it to your PATH:
    tar xzvf uipathctl-linux-amd64.tar.gz
    chmod +x uipathctl
    export PATH=$PATH:$(pwd)
    chmod +x uipathctl
  3. Verify if uipathctl works:
    uipathctl version
    uipathctl version
    The command prints some version information, as shown in the following example:
    Version:       2.2510.0
    Version:       2.2510.0
Running uipathctl on Windows
To run uipathctl on Windows, take the following steps:
    tar xzvf uipathctl-windows-amd64.tar.gz
    Append or prepend the uipathctl binary folder to your PATH environment variable.
    uipathctl version
    uipathctl version
    Version:       2.2510.0
    Version:       2.2510.0
Running uipathctl on MacOS
To run uipathctl on MacOS, take the following steps:
    tar xzvf uipathctl-darwin-amd64.tar.gz
    chmod +x uipathctl
    chmod +x uipathctl
    uipathctl version
    uipathctl version
    Version:       2.2510.0
    Version:       2.2510.0
Telemetry
By default, telemetry is sent from uipathctl to UiPath® at each command execution. This helps us improve our products and user experience.
To opt out of telemetry, set the UIPATHCTL_TELEMETRY_OPTOUT environment variable to 1:
export UIPATHCTL_TELEMETRY_OPTOUT=1
For details, refer to the General configuration section.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
