Temporary registry installation fails on RHEL 8.9
Apply SELinux context fixes to start temporary registry on RHEL 8.9.
When installing a temporary registry on RHEL 8.9, you might encounter an issue that causes the process to fail. This issue occurs due to the deprecated systemd generate command in Podman and the absence of secontext in the systemd files generated by Podman. These conditions prevent systemd from accessing the necessary files, leading to an unsuccessful installation.
Solution
To fix this issue, you must start the container registry by taking the following steps:
  1. Adjust the security context:
    chcon -u unconfined_u -r object_r -t systemd_unit_file_t /etc/systemd/system/container-registry-tmp.service
  2. Reload the systemd manager configuration:
    systemctl daemon-reload
  3. Enable the registry service:
    systemctl enable container-registry-tmp.service
  4. Start the registry service:
    systemctl start container-registry-tmp.service
After starting the container registry using these steps, you do not have to retry the registry installation command.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
