Configuring appSettings
Reference for appSettings configuration via Kubernetes config maps and secrets for Orchestrator in Automation Suite.
The Orchestrator configuration consists of an array of Kubernetes config maps and secrets that are loaded in a specific order, and placed in the appSettings section of config maps.
The latest configuration is loaded from the orchestrator-customconfig config map. Any newly loaded configuration overwrites all existing settings that have the same key.
To display the current custom Orchestrator configuration, use the config orchestrator get-config uipathctl command:
./bin/uipathctl config orchestrator get-config --app-settings
  "key":"value"
  "key":"value"
The uipathctl commands needed for configuring appSettings are:
  • ./bin/uipathctl config orchestrator get-config --app-settings - Exports the current configuration in a key-value pair json file, ready for editing. For details, refer to the uipathctl config orchestrator get-config section.
  • ./bin/uipathctl config orchestrator update-config --app-settings appsettings.json - Updates the configuration with your changes. For details, refer to the uipathctl config orchestrator update-config section.
  1. Export the current custom appSettings configuration to a json file using this command:
    ./bin/uipathctl config orchestrator get-config --app-settings > appsettings.json
  2. Edit the exported appsettings.json file as needed. You can add, remove, or change any of its settings, as shown in the following example:
        "Triggers.DisableWhenFailedCount": "20",
        "Triggers.JobsCountStrategy": "NoLimit"
    Note:
    You must export the file again every time you need to make a change, since the update overwrites all settings.
  3. Update the appSettings configuration using this command:
    orchestrator config updated
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
