Updating external Redis credentials
Update external Redis credentials using cluster_config.json in Automation Suite.
Generating the cluster_config.json file
Generate the latest cluster_config.json file using the following command:
./bin/uipathctl manifest get-revision >> ./cluster_config.json
Note:
For details on how to configure the cluster_config.json parameters, refer to Advanced installation experience.
Providing the new credentials for Redis
Update the following section in the cluster_config.json file with the new password and/or hostname:
"fabric": {
  "redis": {
    "hostname": "new_hostname",
    "password": "new_password",
    "port": 6380,
    "tls": true
"fabric": {
  "redis": {
    "port": 6380,
    "tls": true
Running the installer
To run the installer, use the following command:
cd /opt/UiPathAutomationSuite/{version}/installer
./bin/uipathctl manifest apply ./cluster_config.json --versions versions/helm-charts.json
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
