- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Architecture overview of the UiPath Automation Suite AWS Marketplace deployment, including stack components and Lambda functions.
Architecture diagram
Complete component list
Entry points
The UiPath AWS Marketplace deployment has a single entry point.
Nested stacks
- Uipath-sf:
- SSL stack
- Routing stack
- Server stack
- Database stack
- Backup stack
- Management stack
- Lambda functions (
AWS::Lambda::Function):FindAMIFunction- for finding a matching AMI Id.CreateInputJsonFunction- for creating the configuration used by the Automation Suite installer.ComputeResourceSizeFunction- for computing the minimum EC2 instances hardware configuration needed, based on the selected services and deployment type.
- IAM roles (
AWS::IAM::Role) for the Lambda functions to provide minimum permissions:FindAmiLambdaRoleCreateInputJsonLambdaRoleComputeResourceSizeLambdaRole
- Secrets (
AWS::SecretsManager::Secret) to store sensitive information:RDSPasswordOrgSecretPlatformSecretArgoCdSecretArgoCdUserSecretInputJsonSecretKubeconfigSecret
- SSL Stack (optional)
- Network stack (optional)
- Backup stack (optional):
ClusterBackupStorage(AWS::EFS::FileSystem) - Amazon Elastic File System used to store the backup.SharedStorageSecurityGroup(AWS::EC2::SecurityGroup) - Security group used to allow NFS network connections from the cluster nodes.SharedStorageMountTargetOne(AWS::EFS::MountTarget) - Resource that creates the mount target for the EFS file system and the first private subnet.SharedStorageMountTargetTwo(AWS::EFS::MountTarget) - Resource that creates the mount target for the EFS file system and the second private subnet.SharedStorageMountTargetThree(AWS::EFS::MountTarget) - Optional resource that creates the mount target for the EFS file system and the third private subnet.
- Database stack:
RDSDBInstance(AWS::RDS::DBInstance) - The Amazon RDS DB instance. The DB SKU isdb.m5.2xlarge.DBSubnetGroup(AWS::RDS::DBSubnetGroup) - Private subnet group that contains the private subnets.DbSecurityGroup(AWS::EC2::SecurityGroup) - Security Group allowing access to the DB instance.PMRDSDBInstance(AWS::RDS::DBInstance) - Dedicated Amazon RDS DB instance for Process Mining. Only deployed when Process Mining is enabled and the deployment isMulti Node. The DB SKU isdb.m5.4xlarge.
- Routing stack:NOTE: The Alb and Nlb stacks are mutually exclusive configurations
- Alb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Application load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.ELBSecurityGroup(AWS::EC2::SecurityGroup) - The security group applied to the load balancer.HttpsTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group of the load balancer.HttpsListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the load balancer.
- Nlb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Network load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.TcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group of the load balancer.TcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the load balancer.
KubeLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Private network load balancer used for node registration.KubeApiTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group for the node registration traffic of theKubeLoadBalancer.KubeApiTcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the node registration traffic of theKubeLoadBalancer.RootRecordSet(AWS::Route53::RecordSet) - DNS A record for the FQDN.SubdomainRecordSet(AWS::Route53::RecordSet) - DNS A record for the subdomains of the FQDN.
- Alb stack:
- Management stack:
LifecycleAutomationLogs(AWS::Logs::LogGroup) - Log group for logging events from the SSM automation.ClusterOperationsAutomationLogs- Log group for logging events related to cluster operations.OnDemandRestoreStateMachine(AWS::StepFunctions::StateMachine) - Step function used to orchestrate the restore flow.- SSM Documents (
AWS::SSM::Document) sets of steps used to provide graceful node removal:ServerRemoveInstanceDocumentAgentRemoveInstanceDocumentUpdateAMIDocument- Updates the AMI ID for the Auto Scaling Groups.RegisterAiCenter- Registers AI Center to an external Orchestrator provided at deployment time.OnDemandBackup- Creates a manual snapshot of the Automation Suite cluster.GetBackupList- Retrieves all available snapshots for the Automation Suite cluster.OnDemandRestoreDocument- Restores the Automation Suite cluster from a given snapshot.
- Autoscaling Lyfecycle hooks (
AWS::AutoScaling::LifecycleHook) that allow us to run the SSM documents when an EC2 instance receives an instance termination event:ServerAsgLifeCycleHookTerminatingAgentAsgLifeCycleHookTerminatingAsRobotsAsgLifeCycleHookTerminating
- Event rules (
AWS::Events::Rule) that trigger the execution of the SSM Documents:ServerTerminateEventRuleAgentTerminateEventRuleAsRobotsTerminateEventRule
- IAM roles (
AWS::IAM::Role) needed for running SSM Documents and adding logs to the Log Group:AutomationAssumeRoleEventsBridgeAssumeRoleStateMachinesAssumeRole
Note:AutomationAssumeRoleandStateMachinesAssumeRoleallow full access to Amazon SSN. For details, refer to AmazonSSMFullAccess. - Server stack:
ServerLaunchConfiguration(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the server nodes. Disk configuration:- OS disk - sku gp3, capacity 256GB
- Cluster disk - sku gp3, capacity 300GB
- etcd disk - sku io1, capacity 32GB
- Data disk - sku gp3, capacity 512GB regardless of the selected services.
- Objectstore disk - sku gp3, capacity 512GB
- Optional disk for Automation Suite Robots package caching - sku gp3, capacity 32GB. The disk is deployed only if the the Automation Suite Robots service is enabled in a single-node deployment
AgentLaunchConfiguration(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the agent nodes. Disk configuration:- OS disk - sku gp3, capacity 128GB
- Cluster disk - sku gp3, capacity 256GB
ASRobotsLaunchTemplate(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the ASRobots nodes. Disk configuration:- OS disk - sku gp3, capacity 128GB
- Robot package caching disk - sku gp3, capacity 32GB
GpuEnabledNode(AWS::EC2::Instance) - Optional GPU node. It has the same disk configuration as an agent.BastionHost(AWS::EC2::Instance) - Optional EC2 instance used to SSH to cluster nodes. It has thet3.largeinstance type and a 200GB gp3 disk.ServerAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) - Auto scaling group for the servers.AgentAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) - Auto scaling group for the agents.ASRobotsAutoScalingGroup- Auto scaling Group for dedicated Automation Suite Robots nodes. The capacity of this scaling group is 1 if the deployment isMulti Nodeand the Automation Suite Robots service is enabled, and 0 otherwise.- Optional
ServiceFabricIamRole(AWS::IAM::Role) that has permissions to:- write logs
- read EC2 instances configurations
- download AWS Quickstart resources
- access the Automation Suite installation configuration secret
- access the cluster kubeconfig configuration secret
ServiceFabricSecurityGroup(AWS::EC2::SecurityGroup) - Security Group allowing access to UiPath® applications.BastionSecurityGroup(AWS::EC2::SecurityGroup) - Optional Security Group allowing SSH access to BastionAsgProcessModifierFunction(AWS::Lambda::Function) - Used to modify the ASG processes during CF stack creation.AsgProcessModificationRole(AWS::IAM::Role) - IAM role to provide minimum permissions for theAsgProcessModifierFunction- SSM parameters (
AWS::SSM::Parameter):InstanceAMIIdSSMParameter- Stores the AMI ID of the nodes.InstanceAMIImageNameSSMParameter- Holds the Image Name used at deployment time or updated via theUpdateAMIDocument.
AWS::AutoScaling::LifecycleHook) that allow us to transition EC2 instances to InService state after the installer succeeded:ServerAsgLifeCycleHookLaunchingAgentAsgLifeCycleHookLaunchingASRobotsAsgLifeCycleHookLaunching
Deployment and instance type mapping
The template dynamically computes the hardware needed for the deployment as follows:
- Depending on the services installed, it sets minimum requirements at cluster level.
- Depending on the deployment profile (multi-node or single-node profile), it sets minimum requirements for a single VM.
- Selects the instance types based on their availability in the region you deploy and the aforementioned requirements.
The following table shows the mappings between deployment and possible instance types:
| Deployment type | Instance types |
| Single-node, services selection that needs less than 16 CPUs | c5.4xlarge, c5a.4xlarge, m5.4xlarge, m5a.4xlarge |
| Single-node, services selection that needs more than 16 CPUs | c5a.8xlarge, c5.9xlarge, m5.8xlarge |
| Multi-node, services selection that needs less than 48 CPUs | c5.4xlarge, c5a.4xlarge, m5.4xlarge, m4.4xlarge |
| Multi-node, services selection that needs more than 48 CPUs | c5a.8xlarge, c5.9xlarge, m5.8xlarge, m5a.8xlarge |
