- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for VM configuration steps, including DNS name and IP settings, for Automation Suite deployments on Azure.
Configuring the DNS of the VM
Configuring the DNS on each VM is optional if you are deploying a multi-node HA-ready production setup behind a load balancer.
Select the value of the DNS Name to set the DNS name of the machine.
In the VM IP configuration window displayed, set the DNS name label:
Select Save.
Testing the Connection to the VM
Test the connection to the VM using SSH. Request Just In Time access if needed.
- To connect to the machine using SSH, follow the Azure instructions.
- Alternatively, you can connect to the machine on your terminal using SSH:
# If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm># If you set a password the command is: ssh <user>@<dns_of_vm> # If you used an ssh key: ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Partitioning the Disk
Log in to the machine via SSH using the following commands:
- If you set a password:
ssh <user>@<dns_of_vm>ssh <user>@<dns_of_vm> - If you used an SSH key:
ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>ssh -i <.\Path\To\myKey1.pem> <user>@<dns_of_vm>
Identifying the Device Name for the Disk in Azure
The disk device name is different from the disk name. You will need the disk device name when configuring the disk. Refer to Configuring the disks for details.
In the Disks tab of every VM in the Azure portal, you can find the LUN (Logical Unit Number) corresponding to each attached disk.
Run the following command to identify the disk device name, where
LUN=<lun_value> as identified in the Azure portal:LUN=<lun_value> echo "/dev/$(tree /dev/disk/azure/ | grep -w "\slun${LUN}\s" | awk -F/ '{print $NF}')"LUN=<lun_value> echo "/dev/$(tree /dev/disk/azure/ | grep -w "\slun${LUN}\s" | awk -F/ '{print $NF}')"
Marking the Azure Disk as SSD
This step is required only for data disk and raw disk.
You need to mark the Azure disk as SSD by running the following command:
echo "0" > "/sys/block/{DEVICE_NAME}/queue/rotational"
echo "KERNEL==\"{DEVICE_NAME}\", ATTR{queue/rotational}=\"0\"" >> "/etc/udev/rules.d/99-azure-mark-ssd.rules"
udevadm control --reload
udevadm trigger
udevadm trigger
Multi-node Only: Configuring Additional Ports
These additional inbound ports are needed only for multi-node HA-ready production installations. Add them to all VMs.
| Port | Protocol | Source | Destination | Purpose |
443 | TCP | Any | Any | https traffic |
2379 | TCP | VirtualNetwork | VirtualNetwork | etcd client port |
2380 | TCP | VirtualNetwork | VirtualNetwork | etcd peer port |
6443 | TCP | Any | Any | Kubernetes API |
8472 | UDP | VirtualNetwork | VirtualNetwork | Flannel |
9345 | TCP | Any | Any | Kubernetes API |
10250 | TCP | VirtualNetwork | VirtualNetwork | kubelet |
30071 | TCP | VirtualNetwork | VirtualNetwork | NodePort |
Opening TCP ports on an Azure VM for multi-node installations
Create new inbound networking rules for the ports needed over TCP protocol.
Select the VM's Overview tab, then select the Networking tab:
Select Add inbound port rule.
Change the fields as required:
- Destination port range
- Protocol
- Name
You can add as a comma-separated list with ranges:
Add all the TCP in one inbound rule as previously shown, and the UDP in a separate one. For the UDP, add +1 to the priority.
And select Add.
