Performing post-installation operations
Enable Ceph backup CronJob manually for single-node Automation Suite clusters.
After completing the installation, you must perform a set of required configuration and enablement actions before starting to use the Automation Suite cluster.
  • If you are using a single-node cluster and have provisioned a Ceph backup disk, you must manually enable the Ceph backup CronJob. This job is not applied automatically during installation. For details, refer to How to schedule Ceph backup and restore data.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
