- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Perform routine database maintenance operations to keep Automation Suite databases free from clutter.
It is important to keep your databases free from clutter. To do this, we recommend performing the following operations:
Using SQL Server Maintenance Solution
SQL Server Maintenance Solution is a set of scripts that enable you to run backups, integrity checks, and index and statistics maintenance on all editions of Microsoft SQL Server, starting with the 2005 version. For details, refer to this GitHub project.
Backing up the database
We recommend implementing regular backups of the SQL Server database, such as full weekly or daily incremental backups.
Additionally, we recommend using the DatabaseBackup stored procedure that is created using the script at this location.
Deleting old data periodically
Shared Suite Capabilities
Create a separate database in which to save items before you delete them. This database acts as an archive for the items you may need to store for certain reasons, such as audits.
Create a new database called, for example,
UiPathArchives:create database UiPathArchivescreate database UiPathArchives -
Create the following backup tables:
ArchiveAuditEventwith the same structure as theAuditEventtable:SELECT * INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] from [AutomationSuite_Platform].[adt].[AuditEvent] where 1 = 2SELECT * INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] from [AutomationSuite_Platform].[adt].[AuditEvent] where 1 = 2 -
Archive the data.
To archive audit event records, use the following example script:
DECLARE @NumberOfDaysToKeep INT DECLARE @CurrentDate DATETIME -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Archive the list of audit event records that you want to delete SET @CurrentDate = GetDate() BEGIN TRANSACTION INSERT INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Delete the audit events DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM [UiPathArchives].[dbo].[ArchiveAuditEvent] WHERE Id = [adt].[AuditEvent].[Id]) COMMIT TRANSACTIONDECLARE @NumberOfDaysToKeep INT DECLARE @CurrentDate DATETIME -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Archive the list of audit event records that you want to delete SET @CurrentDate = GetDate() BEGIN TRANSACTION INSERT INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Delete the audit events DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM [UiPathArchives].[dbo].[ArchiveAuditEvent] WHERE Id = [adt].[AuditEvent].[Id]) COMMIT TRANSACTIONOld data is copied to these archives prior to being deleted when using the following query.
Delete data from the table.
Important:Before running the following script, make sure to adapt them to your environment.
Audit events:
declare @NumberOfDaysToKeep int declare @CurrentDate datetime -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Create temporary table with the list of audit event records that you want to delete SET @CurrentDate = GetDate() SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] INTO #TempAuditRecordsToDelete FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Review the audit event records to be deleted SELECT * FROM #TempAuditRecordsToDelete -- Delete the audit events BEGIN TRANSACTION DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM #TempAuditRecordsToDelete WHERE Id = [adt].[AuditEvent].[Id]) DROP TABLE #TempAuditRecordsToDelete COMMIT TRANSACTIONdeclare @NumberOfDaysToKeep int declare @CurrentDate datetime -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Create temporary table with the list of audit event records that you want to delete SET @CurrentDate = GetDate() SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] INTO #TempAuditRecordsToDelete FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Review the audit event records to be deleted SELECT * FROM #TempAuditRecordsToDelete -- Delete the audit events BEGIN TRANSACTION DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM #TempAuditRecordsToDelete WHERE Id = [adt].[AuditEvent].[Id]) DROP TABLE #TempAuditRecordsToDelete COMMIT TRANSACTION
Identity Server
The database maintenance script provided in this section is supported only when using SQL Server on-premises. It does not work with Azure SQL. If your Automation Suite deployment uses Azure SQL, do not run this script.
UiPathIdentityArchives:create database UiPathIdentityArchivescreate database UiPathIdentityArchives -
ArchiveLoginAttemptswith the same structure as theUserLoginAttemptstable:select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [AutomationSuite_Platform].[identity].[UserLoginAttempts] where 1=2select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [AutomationSuite_Platform].[identity].[UserLoginAttempts] where 1=2Old data is copied to these archives prior to being deleted when using the following query.
To delete login attempts older than 60 days, for example, use the following query. It can be executed manually or scheduled in an SQL Server Job.
declare @NumberOfDaysToKeep int set @NumberOfDaysToKeep = 60 if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end begin transaction set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]) select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName] from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep commit transactiondeclare @NumberOfDaysToKeep int set @NumberOfDaysToKeep = 60 if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end begin transaction set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]) select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName] from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep commit transaction
Orchestrator
For details on how to periodically delete old data from the Orchestrator database, refer to Cleaning up the Orchestrator database.
Automation Hub
Automation Hub relies on its historical data for runtime views and dashboards, and due to its nature, it does not have the concept of cleaning up old data. Similar to other services, it is recommended to regularly back up the Automation Hub database through methods such as full weekly backups or daily incremental backups.
Process Mining
Process Mining on Automation Suite provides built-in automatic database cleanup ensuring optimal efficiency and performance. This guarantees the regular removal of unnecessary data, keeping your database cleaned up and functional without the need for any manual actions to free up resources.
