- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Active/Passive and Active/Active deployment topologies in Automation Suite, including diagrams and hardware requirements.
Diagrams
The following diagram depicts a regular Active/Passive deployment of Automation Suite:
The following diagram depicts a regular Active/Active deployment of Automation Suite:
Requirements
The following hardware components are required for Active/Passive and Active/Active deployments.
Global Traffic Manager (GTM)
The GTM distributes traffic across your Automation Suite multi-site deployment. It must be highly available and immune to failure at any single deployment site. The GTM must also support health checks that isolate a faulty site quickly. The GTM is not mandatory, but it is recommended for a quick switchover.
When configuring the GTM for Active/Passive or Active/Active deployments, use /orchestrator_/api/status as the health endpoint. This is critical for effective disaster recovery management.
Load balancer
Every site needs a local load balancer that can load-balance traffic to any node configured in the same site. For details, refer to Configuring the load balancer.
Node
Every site must have at least three servers; agent nodes are optional. The exact number of machines depends on the machine size and overall capacity requirements. You do not need to bring the same set of nodes to each cluster.
For Active/Active configurations, the secondary cluster can be smaller, since you might install only a few products. For details, refer to Automation Suite Install Sizing Calculator.
SQL database
An external SQL server is required to store the data. For disaster recovery, you need Always On Availability Groups with a primary SQL server in Site 1 and at least one secondary SQL server physically located in Site 2, with data sync enabled. A SQL listener is deployed on top of the SQL server, and both clusters are configured to use the address of the same listener.
PostgreSQL database
PostgreSQL is used only by Process Mining. Process Mining is not supported in Active/Passive or Active/Active mode, so its Airflow database does not need to be persisted to the secondary site. No cross-site PostgreSQL replication is required for disaster recovery.
Objectstore
Any files or packages uploaded to products are stored in the objectstore. For greater resilience to failure, Automation Suite deployments require an external objectstore.
For effective disaster recovery, two objectstore instances are required, one in each data center. At any given time, only one objectstore instance must be actively used for reading and writing by both clusters, complemented by asynchronous replication to the secondary instance.
For Active/Active, High Availability Add-on must be external to Automation Suite and installed on separate machines. A minimum of three nodes is required for each High Availability Add-on instance in both data centers, configured in different clusters and synchronized through CRDB replication. To install High Availability Add-on, refer to the High Availability Add-on Installation Guide.
For Active/Passive, High Availability Add-on is installed within the Automation Suite cluster. You must still enable it on both clusters by providing the HAA license. For details, refer to Enabling Redis High Availability Add-On for the cluster.
Elasticsearch (optional)
Elasticsearch is required to send the robot logs. You can configure Elasticsearch cross-site replication as described by Elasticsearch.
