Frequent restart issue in uipath namespace deployments during offline installations
Synchronize certificates between namespaces to resolve deployment restart loops in offline Automation Suite.
Certain deployments in the uipath namespace are restarting frequently in offline installations. This is due to the Reloader component, which restarts applications whenever the istio-ingressgateway-certs secret is updated.
If the istio-ingressgateway-certs secret is inconsistent between the istio-system and docker-registry namespaces, Reloader continuously updates the secret in the uipath namespace, causing frequent restarts.
Solution
To address the issue, you must synchronize the istio-ingressgateway-certs secret between the istio-system and docker-registry namespaces by running the following command:
 kubectl get secret -n istio-system istio-ingressgateway-certs -o json |jq 'del( .metadata.uid, .metadataresourceVersion, .metadata.creationTimestamp, .status, .metadata.annotations, .metadata.resourceVersion, .metadata.namespace)'  | kubectl  apply -n docker-registry -f -
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
