- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Cluster_config.json sample
Reference for the cluster_config.json sample configuration file and its parameters in Automation Suite.
"fqdn": "PLACEHOLDER",
"cluster_fqdn": "PLACEHOLDER",
"fixed_rke_address": "PLACEHOLDER",
"admin_username": "PLACEHOLDER",
"admin_password": "PLACEHOLDER",
"rke_token": "PLACEHOLDER ",
"zone_resilience": false,
"registries": {
"docker": {
"url": "registry.uipath.com"
"helm": {
"sql_connection_string_template": "PLACEHOLDER",
"sql_connection_string_template_jdbc": "PLACEHOLDER",
"sql_connection_string_template_odbc": "PLACEHOLDER",
"sql_connection_string_template_sqlalchemy_pyodbc": "PLACEHOLDER",
"orchestrator": {
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"enabled": true
"infra": {
"docker_registry": {
"username": " PLACEHOLDER ",
"password": " PLACEHOLDER "
"pod_log_path": ""
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true,
"datamanager": {}
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"insights": {
"enabled": true
"integrationservices": {
"enabled": true
"dataservice": {
"enabled": true
"asrobots": {
"enabled": true,
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache"
"processmining": {
"enabled": true
"external_object_storage": {
"enabled": false
"identity_certificate": {},
"profile": "ha",
"network": {
"ipv4": { "enabled": true },
"ipv6": { "enabled": true }
"telemetry_optout": false,
"alternative_fqdn": "",
"server_certificate": {
"ca_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/rootCA.crt",
"tls_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/server.crt",
"tls_key_file": "/opt/UiPathAutomationSuite/UiPath_Installer/server.key"
"alternative_certificate": {
"ca_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-rootCA.crt",
"tls_cert_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-server.crt",
"tls_key_file": "/opt/UiPathAutomationSuite/UiPath_Installer/alt-server.key"
"istioMinProtocolVersion": "TLSV1_3"
"registries": {
"docker": {
"helm": {
"orchestrator": {
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"enabled": true
"infra": {
"pod_log_path": ""
"platform": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"action_center": {
"enabled": true
"aicenter": {
"enabled": true
"enabled": true,
"datamanager": {}
"apps": {
"enabled": true
"test_manager": {
"enabled": true
"insights": {
"enabled": true
"enabled": true
"dataservice": {
"enabled": true
"asrobots": {
"enabled": true,
"processmining": {
"enabled": true
"enabled": false
"profile": "ha",
"network": {
