- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Configuring an allowlist for connector domains
- Configuring the queue FQDN suffix for sovereign cloud deployments
- Configuring Service Principal authentication for SQL
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
If you have restrictions in place that prevent data from leaving your cluster, you must configure an allowlist for the specific domain of each connector you want to use.
For some connectors, the domain may depend on values or credentials you provide during connection creation.
The following table lists the domains you must add to the allowlist for each connector and provides samples for some of them.
| Connector | Domain |
| Act! 365 | app.act365.com |
| ActiveCampaign | Based on user sandbox. Sample: uipath1663561860.api-us1.com |
| Active Directory | Based on user sandbox. |
| Adobe Acrobat Sign | Based on user sandbox. |
| Adobe PDF Services | pdf-services-{environment}.adobe.io |
| Amazon Bedrock | Based on user sandbox. |
| Amazon Connect | Based on user sandbox. Sample: connect.{aws.region}.amazonaws.com |
| Amazon Polly | Based on user sandbox. Sample: polly.{aws.region}.amazonaws.com |
| Amazon SES | Based on user sandbox. Sample: email.{aws.region}.amazonaws.com |
| Amazon Transcribe | Based on user sandbox. Sample: transcribe.{aws.region}.amazonaws.com |
| Amazon Web Services | Based on user sandbox. Sample: {serviceName}.{region}.amazonaws.com |
| Anthropic Claude | api.anthropic.com |
| Asana | Based on user sandbox. Sample: app.asana.com |
| Azure AI Document Intelligence | Based on user sandbox. Sample: {endpoint}.cognitiveservices.azure.com |
| AWeber | api.aweber.com |
| Azure Maps | atlas.microsoft.com |
| BambooHR | api.bamboohr.com |
| Box | api.box.com |
| Brevo | api.brevo.com/v3 |
| Calendly | api.calendly.com |
| Campaign Monitor | api.createsend.com |
| Citrix ShareFile | Based on user sandbox. Sample: {subdomain}.{apicp}/sf/v3 |
| Cisco Webex Teams | webexapis.com |
| Citrix Hypervisor | Based on user sandbox. |
| Clearbit | person.clearbit.com |
| Confluence Cloud | api.atlassian.com |
| Constant Contact | api.cc.email |
| Customer.io | track.customer.io |
| Datadog | Based on user sandbox. |
| DeepSeek | api.deepseek.com |
| Deputy | Based on user sandbox. |
| DocuSign | Based on user sandbox. |
| Drip | api.getdrip.com |
| Dropbox | api.dropboxapi.com/2 |
| Egnyte | Based on user sandbox. |
| Eventbrite | eventbriteapi.com |
| Exchangerates | api.exchangeratesapi.io |
| Expensify | integrations.expensify.com |
graph.facebook.com | |
| FreshBooks | api.freshbooks.com |
| Freshdesk | Based on user sandbox. Sample: {domain}.freshdesk.com |
| Freshsales | Based on user sandbox. Sample: {domain}.myfreshworks.com/crm/sales/api, {domain}.freshsales.io/api/ |
| Freshservice | Based on user sandbox. Sample: clouddeveloper.freshservice.com |
| GetResponse | api.getresponse.com/v3 |
| GitHub | api.github.com |
| Gmail | googleapis.com |
| Google Cloud Platform | compute.googleapis.com |
| Google Docs | docs.googleapis.com |
| Google Drive | googleapis.com |
| Google Maps | maps.googleapis.com |
| Google Sheets | sheets.googleapis.com |
| Google Speech-to-Text | speech.googleapis.com |
| Google Text-to-Speech | texttospeech.googleapis.com |
| Google Vertex | Based on user sandbox. Sample: {region}-aiplatform.googleapis.com |
| Google Vision | vision.googleapis.com |
| Google Workspace | googleapis.com |
| GoToWebinar | api.getgo.com |
| Hootsuite | platform.hootsuite.com |
| HubSpot Marketing | api.hubapi.com |
| HubSpot CRM | api.hubapi.com |
| HyperV | Based on user sandbox. |
| Icertis | Based on user sandbox. Sample: {tenantName}.icertis.com/api |
| iContact | app.icontact.com |
| Insightly CRM | api.insightly.com |
| Intercom | Based on user sandbox. |
| Jina AI | api.jina.ai/v1, r.jina.ai |
| Jira | For OAuth 2.0 app: api.atlassian.comFor Basic authentication: based on user sandbox. |
| Keap | api.infusionsoft.com |
| Klaviyo | a.klaviyo.com |
api.linkedin.com | |
| Mailchimp | Based on user sandbox. |
| Mailgun | Based on user sandbox. |
| MailerLite | connect.mailerlite.com |
| Mailjet | api.mailjet.com |
| Marketo | Based on user sandbox. Sample: 136-TVZ-720.mktorest.com |
| Microsoft 365 | graph.microsoft.com |
| Microsoft Azure | management.azure.com |
| Microsoft Azure OpenAI | Based on user sandbox. Sample: {subdomain}.openai.azure.com |
| Microsoft Azure Active Directory | graph.microsoft.com |
| Microsoft Dynamics 365 CRM | Based on user sandbox. |
| Microsoft Outlook 365 (Legacy) | graph.microsoft.com |
| Microsoft Outlook 365 | graph.microsoft.com |
| Microsoft Sentiment | Based on user sandbox. |
| Microsoft Teams | graph.microsoft.com |
| Microsoft Translator | api.cognitive.microsofttranslator.com |
| Microsoft Vision | Based on user sandbox. Sample: {subscription.region}.api.cognitive.microsoft.com |
| Miro | api.miro.com |
| NetIQ eDirectory | Based on user sandbox. |
| Okta | Based on user sandbox. |
| OpenAI | api.openai.com |
| Oracle Eloqua | Based on user sandbox. |
| Oracle Netsuite | Based on user sandbox. |
| PayPal | {environment}.paypal.com |
| PDFMonkey | api.pdfmonkey.io |
| Perplexity | api.perplexity.ai |
| Pinecone | Based on user sandbox. |
| Pipedrive | api.pipedrive.com |
| QuickBooks Online | Based on user sandbox. |
| Quip | platform.quip.com/ |
| Salesforce | Based on user sandbox. Sample: uipath-b1-dev-ed.develop.my.salesforce.com |
| Salesforce Marketing Cloud | Based on user sandbox. Sample: {tenantName}.rest.marketingcloudapis.com |
| SAP Concur | Based on user sandbox. |
| SAP Cloud for Customer | Based on user sandbox. Sample: {tenantName}.crm.ondemand.com |
| SAP BAPI | Based on user sandbox. |
| SAP OData | {sap_host}/sap/opu/odata/sap |
| SendGrid | api.sendgrid.com/v3/ |
| ServiceNow | Based on user sandbox. |
| Shopify | Based on user sandbox. Sample: {store_name}.myshopify.com |
| Slack | slack.com |
| SmartRecruiters | api.smartrecruiters.com |
| Smartsheet | Based on user sandbox. Sample: api.{region} |
| Snowflake | Based on user sandbox. Sample: cz99177.west-us-2.azure.snowflakecomputing.com |
| Stripe | api.stripe.com |
| Sugar Enterprise | Based on user sandbox. |
| Sugar Professional | Based on user sandbox. |
| Sugar Sell | Based on user sandbox. |
| Sugar Serve | Based on user sandbox. |
| System Center | Based on user sandbox. |
| TangoCard | Based on user sandbox. Sample: {environment}.tangocard.com/raas/v2 |
| Todoist | api.todoist.com |
| Trello | api.trello.com |
| Twilio | api.twilio.com |
| VMware ESXi vSphere | Based on user sandbox. |
| X | api.twitter.com |
| WhatsApp Business | graph.facebook.com |
| WooCommerce | Based on user sandbox. |
| Workable | Based on user sandbox. Sample: {subdomain}.workable.com |
| Workday | Based on user sandbox. |
| YouTube | googleapis.com/youtube/v3 |
| IBM watsonx.ai | us-south.ml.cloud.ibm.com |
| Zendesk | Based on user sandbox. Sample: {tenantName}.zendesk.com |
| Zoho Campaigns | Based on user sandbox. |
| Zoho Desk | Based on user sandbox. Sample: desk.{environment} |
| Zoom | api.zoom.us |
| ZoomInfo | api.zoominfo.com |
| Zoho Mail | Based on user sandbox. |
