- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for certificate configuration options in Automation Suite, including self-signed and custom certificate setup.
If no certificate is provided at the time of installation, the installer creates self-issued certificates and configures them in the cluster.
The validity of the self-signed certificates is 90 days.
For details on how to obtain a certificate, refer to Managing the certificates.
Note:
Make sure to specify the absolute path for the certificate files. Run pwd to get the path of the directory where files are placed and append the certificate file name to the cluster_config.json.
In multi-node HA-ready production installations, a certificate is required only on the first node.
| Parameter | Description |
server_certificate.ca_cert_file | Absolute path to the Certificate Authority (CA) certificate. This CA is the authority that signs the TLS certificate. A CA bundle must contain only the chain certificates used to sign the TLS certificate. The chain limit is nine certificates. If you use a self-signed certificate, you must specify the path to rootCA.crt, which you previously created. Leave blank if you want the installer to generate it. |
server_certificate.tls_cert_file | Absolute path to the TLS certificate (server.crt is the self-signed certificate). Leave blank if you want the installer to generate it.If you provide the certificate yourself, the server.crt file must contain the entire chain: -----server cert----- followed by -----root ca chain-----. |
server_certificate.tls_key_file | Absolute path to the certificate key (server.key is the self-signed certificate). Leave blank if you want the installer to generate it. |
identity_certificate.token_signing_cert_file | Absolute path to the identity token signing certificate used to sign tokens (identity.pfx is the self-signed certificate). Leave blank if you want the installer to generate an identity certificate using the server certificate. |
identity_certificate.token_signing_cert_pass | Plain text password set when exporting the identity token signing certificate. |
additional_ca_certs | Absolute path to the file containing the additional CA certificates that you want to be trusted by all the services running as part of Automation Suite. All certificates in the file must be in valid PEM format.For example, you need to provide the file containing the SQL server CA certificate if the certificate is not issued by a public certificate authority. |
