- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Note:
For step-by-step instructions, refer to Upgrading Automation Suite.
Execution steps
A successful upgrade requires that both clusters are on the same version. To upgrade the clusters, you must follow the standard upgrade procedure of the standalone Automation Suite cluster, individually for each clusters.
Important:
Before performing the upgrade, make sure to add the type field to the multisite section of your cluster_config.json. Set the value to active-active or active-passive depending on your deployment type.
"multisite": {
"enabled": true,
"primary": true,
"other_kube_config": "",
"type": "active-active"
"multisite": {
"enabled": true,
"primary": true,
You must take the following high-level steps on each cluster separately:
- Hydrate the Docker registry for both clusters.
- Enable the backup of the primary cluster. Optionally, you can also enable the backup for the secondary cluster.
- Put both clusters into maintenance mode.
- Upgrade both the cluster individually.
- Disable the maintenance mode once the upgrade is a success.
Rollback on error
- Primary cluster recovery - you must use the backup to restore the Automation Suite cluster.
- Secondary cluster recovery - you can either use the backup to restore the data if you enabled it before the upgrade, or you can choose to build the new secondary cluster from the primary. The steps here will remain the same as adding a new secondary Automation Suite cluster.
