- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for disk partitioning and LVM configuration required before installing Automation Suite.
Before performing an Automation Suite installation, you must partition and configure the disk using LVM, so that you can alter its size easily and without any data migration or data loss.
Partitioning the disks
The default partitioning structure on RHEL machines is not suitable for installing Kubernetes. This is because the Kubernetes infrastructure is usually installed under the /var partition, which is allocated only 8 GB of space by default.
- The supported format for the disks is
ext4orxfs. - You must create all partitions using LVM to ensure that the cluster data can reside on a different disk but still be viewed coherently. This also helps extend the partition size in the future without the risk of data migration or loss.
- All the pods and application logs are stored under the
/var/log/podsdirectory. Make sure that the capacity of this directory is at least 8 GB. We also recommend configuringlogrotateto rotate the logs at an interval ranging from daily to weekly. - If you use a single-node RKE2 setup with in-cluster storage, it is mandatory to provide at least an additional 512 GB of disk space for the storage of Ceph data backups. This disk is required during installation, but the backup CronJob that uses it must be configured after the cluster is fully installed. For details, refer to Performing post-intallation operations.
The disk requirements for online and offline installations are the same, except for the extra space needed to unpack the offline UiPath® bundle.
For the RHEL OS, make sure you have the following minimum mount point sizes on the machine.
| Disk label | Server | Agent | Partition | Size | Purpose |
| Cluster disk If you enable Document Understanding modern projects, the minimum size is 400 GB. | ✅ | ✅ |
| 190 GB 334 GB minimum when Document Understanding modern projects is enabled | Stores the container images and layers. |
| 56 GB | Stores runtime Kubernetes configurations such as secrets, configmaps, and emptyDir. | |||
| 10 GB | Stores the installer binary. | |||
| etcd disk | ✅ | ❌ |
| 16 GB | Stores the distributed database for Kubernetes |
| Data disk | ✅ | ❌ |
| 15 GB | Required for Insights. |
| 50 GB | Required for the monitoring tools. | |||
/datadisk/registry 1 | 200 GB | Required for the Docker registry. | |||
/datadisk/objectstore 2 | 10 GB | Required for ceph-mon. | |||
| Objectstore 2 | ✅ | ❌ | N/A | 512 GB | Required for in-cluster objectstore. |
| AI Center 3 | ✅ | ✅ | N/A | 51 GB minimum and 105 GB recommended for 1 training pipeline. | Required only if you install AI Center. |
| UiPath® bundle disk | ✅ | ❌ | /uipath | 512 GB | Required only for offline installations to store the offline bundle |
| Ceph backup | ✅ | ❌ | /backup | 512 GB | Required only for single-node RKE2 setup with in-cluster storage, to store Ceph data backups. |
1 This refers to the in-cluster Docker registry and is not applicable if you use an external registry.
2 This refers to the in-cluster objectstore and is not applicable if you use an external objectstore.
3 This refers to the storage required by the AI Center training pipeline. The disk is required only on the machines on which you plan to run the AI Center training pipeline. We recommend attaching this disk on the agent machines.
We recommend that you do not use OS disk for any of the previous purposes, to ensure processes get their fair share of resources.
Using uipathctl to configure the disks
We recommend using uipathctl to configure the disks. The following examples use uipathctl, but you can use your own tools instead.
Downloading uipathctl
uipathctl is a part of the as-installer.zip installation package. To use uipathctl, take the following steps:
Download
as-installer.zipand save it to a temporary location. For the download instructions, refer to as-installer.zip. -
Extract the contents by running the following command:
unzip as-installer.zip -d installerunzip as-installer.zip -d installer
For details on how to use uipathctl to configure the disks, run the following command:
./bin/uipathctl rke2 disk --help
Configuring the cluster disk on all the machines
To identify the correct disk, run lsblk to list all block devices and their sizes, then compare the output against the cluster disk sizes in the hardware requirements table. The disk must be large enough to accommodate all three mount points listed in the table.
To configure the cluster disk, run the following command on all the machines:
./bin/uipathctl rke2 disk --cluster-disk-name <name_of_cluster_disk>
Configuring the etcd disk on all the server machines
To configure the etcd disk, run the following command on all the server machines:
./bin/uipathctl rke2 disk --etcd-disk-name name_of_etcd_disk
The etcd disk configuration must be performed only after completing the cluster disk configuration.
The order of configuration must be preserved, because the etcd disk is mounted inside the cluster disk.
If this step is executed before configuring the cluster disk, it can lead to data loss after a machine reboot, since the kernel automatically mounts disks in sequence, first the cluster disk and then the etcd disk.
Configuring the data disk on all the server machines
To configure the data disk, you must identify the specific disk to be used. Run the lsblk command to list all the block devices, their sizes, and mount points. Use the disk size to identify the relevant disk (for the --volume flag, the 512 GB data disk should be used).
Run the following command on all the server machines and provide the necessary flags based on your requirements:
./bin/uipathctl rke2 disk --volume name_of_data_disk
| Flag | Value |
| Disk name example: /dev/sdeYou need the disk name when partitioning the disks that host the various mounts for monitoring, Insights, objectstore, and registry. uipathdatavg is used to create the partition for the selected component. |
| Optional. Only required if the external registry is not available. |
| Optional flag. The monitoring partition (Prometheus storage) is mandatory, so it is automatically created even if the flag is not specifically passed during the first run execution. However, the flag is required in the subsequent run, during the resize of the monitoring partition along with the |
| Optional flag. Only required if the external objectstore is not available. When used, it also creates the datadisk partition required for ceph-mon. For details, refer to Partitioning the disks. |
| Optional flag. The Insights partition is automatically created even if the flag is not specifically passed during the first run execution. Insights storage configuration is required at infrastructure installation to allow you to enable Insights post-installation. --size flag. |
| Optional. If the integer value is provided, the selected component is resized, provided that enough space is available. Otherwise, the entire disk is consumed to expand the selected partition. It is mandatory to indicate precisely one partition that must be resized. The |
| Path to the location on the Automation Suite Robots node to download the package for caching. This must be performed only on the Automation Suite Robots node. |
You can also use the command to resize the selected partition with the help of the --size flag, as shown in the following example:
./bin/uipathctl rke2 disk --docker-registry --size 300
Configuring the objectstore disk on all the server machines
This step is only required if the external objectstore is not available.
You can add or expand your storage size for the in-cluster objectstore by running the following script on all server nodes:
./bin/uipathctl rke2 disk --ceph-raw-disk-name name_ceph_raw_disk
- An Azure known issue incorrectly marks the Azure disk as non-SSD. If Azure is your cloud provider, and you want to configure the Objectstore disk, refer to Troubleshooting.
- Vertical scaling of the existing disks is not supported. To increase the size of your in-cluster storage post-installation, add new raw disks.
Configuring the AI Center disk on selected machines
To configure the AI Center disk, run the following command on the machines where you plan to execute the training pipelines:
./bin/uipathctl rke2 disk --aicenter-disk-name name_of_aicenter_disk_to_partition
To extend the storage for AI Center:
If you want to add a new AI Center disk, run the following command on the machine where you plan to add the disk:
./bin/uipathctl rke2 disk --aicenter-storage-extend name_of_new_aicenter_disk_to_attach./bin/uipathctl rke2 disk --aicenter-storage-extend name_of_new_aicenter_disk_to_attach -
If you have expanded the existing AI Center disk, run the following command on the machine where the underlying AI Center disk is expanded:
./bin/uipathctl rke2 disk --aicenter-storage-extend./bin/uipathctl rke2 disk --aicenter-storage-extend
Configuring the hosting disk for the Automation Suite Robot package cache
This step is required for single-node setups without a dedicated Automation Suite Robot agent.
To host the Automation Suite Robot package cache on the server node, you need to create a disk of at least 10 GB:
./bin/uipathctl rke2 disk --volume name_of_data_disk --robot-package-cache
It is recommended that the disk is backed up by LVM.
Configuring the bundle disk on the first server node for the in-cluster registry
This step is required in the following scenarios:
- When performing an offline (air-gapped) installation;
- When an external registry is not available.
To configure the bundle disk, run the following command only on the first server node:
./bin/uipathctl rke2 disk --bundle-disk-name name_of_bundle_disk
Configuring the Ceph backup disk on the server node
This step is required only for single-node RKE2 setups with in-cluster storage to back up the Automation Suite cluster.
Run the following command on the server node:
./bin/uipathctl rke2 disk --backup-disk-name <disk-name>
Validating disk mounts
Make sure to add all mount points to the fstab file and to include the nofail option in those fstab entries so that it does not affect the VM boot in case of failure.
To validate that /etc/fstab is correctly configured and can handle a reboot of the system, take the following steps, run the following command:
mount -afv
mount -afv
You should get the following output:
# Servers
/datadisk/monitoring : already mounted
/datadisk/insights : already mounted
/var/lib/rancher/rke2/server/db : already mounted
# Servers or agents
/opt/UiPathAutomationSuite : already mounted
/var/lib/rancher : already mounted
/var/lib/kubelet : already mounted
# In case of an offline environment, only on the primary server node
/uipath : already mounted
# Additional mount point is require if customer is installing offline with internal registry
/datadisk/registry : already mounted
# Additional mount point is require if customer is using in-cluster objectstore
/datadisk/objectstore : already mounted
# Servers
# Servers or agents
- Partitioning the disks
- Using uipathctl to configure the disks
- Downloading uipathctl
- Configuring the cluster disk on all the machines
- Configuring the etcd disk on all the server machines
- Configuring the data disk on all the server machines
- Configuring the objectstore disk on all the server machines
- Configuring the AI Center disk on selected machines
- Configuring the hosting disk for the Automation Suite Robot package cache
- Configuring the bundle disk on the first server node for the in-cluster registry
- Configuring the Ceph backup disk on the server node
- Validating disk mounts
