Airflow installation fails with sqlalchemy.exc.ArgumentError: Could not parse rfc1738 URL from string ''
Known issue and resolution for Airflow installation failures caused by incorrect SQLAlchemy PYODBC connection strings in Automation Suite.
Possible cause
The sqlalchemy PYODBC connection strings for Process Mining are not defined correctly in the cluster_config.json.
Solution
  1. Check the processmining section in the cluster_config.json to verify if connections strings are specified properly.
  2. Check if there is sqlalchemy_pyodbc_sql_connection_str specified.
Note:
If the sqlalchemy_pyodbc_sql_connection_str is not specified in the processmining section it should be specified in template string sql_connection_string_template_sqlalchemy_pyodbc
  • Possible cause
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
