Insights-specific configuration
Reference for Insights-specific configuration parameters, including SMTP settings, for Automation Suite.
If enabling Insights, users can include SMTP server configuration that will be used to send scheduled emails/alert emails. If not provided, scheduled emails and alert emails will not function.
You can use the uipathctl command-line tool to apply configuration changes. For details, refer to the uipathctl reference guide.
The insights.smtp_configuration fields details:
ParameterDescription
tls_versionValid values are TLSv1_2, TLSv1_1, SSLv23. Omit key altogether if not using TLS.
from_emailAddress that alert/scheduled emails will be sent from.
hostHostname of the SMTP server.
portPort of the SMTP server.
usernameUsername for SMTP server authentication.
passwordPassword for SMTP server authentication.
enable_realtime_monitoringFlag to enable Insights Real-time monitoring. Valid values are true, false. Default value is false.
Example
"insights": {
    "enabled": true,
    "enable_realtime_monitoring": true,
    "smtp_configuration": {
      "tls_version": "TLSv1_2",
      "from_email": "test@test.com",
      "host": "smtp.sendgrid.com",
      "port": 587,
      "username": "login",
      "password": "password123"
"insights": {
    "enabled": true,
      "port": 587,
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
