How to exclude buckets from backup
Exclude specific buckets from Velero backup by setting the EXCLUDE_BUCKETS environment variable on the backup-hook-service deployment.
To exclude specific buckets from backup, take the following steps:
  1. Edit the backup-hook-service deployment:
    kubectl -n uipath-infra edit deployment backup-hook-service
  2. Add the EXCLUDE_BUCKETS environment variable to the backup-hook-service container's env section:
    - name: EXCLUDE_BUCKETS
      value: "bucket-name-1,bucket-name-2"
  3. Wait for the new pod to roll out:
    kubectl -n uipath-infra rollout status deployment/backup-hook-service
  4. Verify the environment variable on the running pod:
    kubectl -n uipath-infra exec deploy/backup-hook-service -c backup-hook-service -- env | grep EXCLUDE
    The expected output is as follows:
    EXCLUDE_BUCKETS=bucket-name-1,bucket-name-2
  5. Confirm that the excluded buckets are skipped on the next Velero backup:
    kubectl -n uipath-infra logs -f deploy/backup-hook-service -c backup-hook-service | grep -i 'skipping'
Result
The specified buckets are skipped during future Velero backup runs. The backup-hook-service logs confirm each skipped bucket with output similar to the following:
[WARN] ... Skipping backup for bucket: 'bucket-name-1' Found in exclude list
  • Result
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
