Step 12: Validating and installing the required RPM packages
Validate and install the required RPM packages as part of the Automation Suite installation prerequisites.
Note:
For a list of RPM package requirements, refer to Hardware and software requirements.
To validate and install the required RPM packages, take the following steps:
  1. Navigate to the installer folder:
    cd /opt/UiPathAutomationSuite/<version>/installer
  2. To validate the RPM packages, run the following command:
    ./bin/uipathctl rke2 prereq run --only rpm
  3. To install the RPM packages, run the following command:
    ./bin/uipathctl rke2 prereq create --only rpm
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
