- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Adding a new node to the cluster
- Removing a node from the cluster
- Repaving a cluster node
- Starting and shutting down a node
- Renaming a node
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Start and shut down nodes safely in Automation Suite, covering manual and automatic startup and shutdown behavior.
This page explains the manual and automatic startup and shutdown behavior of Automation Suite.
You must always proceed by shutting down one node, performing the required operation, waiting until the node is healthy, and then taking down the other node to perform the same operation.
The following table describes different scenarios you may experience when shutting down cluster services or nodes. The table provides detailed actions you must take for each situation, alongside guidance on understanding the expected behavior in response to these actions.
| Scenario | Action | Expected behavior |
| Shutting down cluster services on one node without turning off the node, for maintenance or any other reason. |
| In an HA scenario, most services will remain up. The node should start up without any issue and any down services should restart. |
| Shutting down all cluster services without turning off nodes, for maintenance or any other reason. |
| Services will become unavailable. Nodes should startup without issue. |
| Shutting down all nodes. | If your hypervisor management portal (such as VMware, AWS) allows for services to graceful shutdown without force terminating the machine, carry out a normal shutdown. By default, systemd subsystem allows a grace period for services to shutdown before they are forcefully terminated. However, if your system overwrites configured shutdown times, it may interfere with a graceful shutdown. For example, on AWS, the platform can force terminate a VM after two minutes. As such, the services must be shut down manually as a node drain can take up to 5 minutes (this is a requirement of a graceful shutdown). | If the shutdown is graceful, the nodes should start up without issue. If the cluster was shut down for more than 6 hours and Kerberos authentication is configured, you may need to renew Kerberos tickets after restart. For details, refer to Recovering Kerberos Authentication After VM Restart. |
| Shutting down an individual node. | If your hypervisor management portal (such as VMware, AWS) allows for services to graceful shutdown without force terminating the machine, carry out a normal shutdown. By default, systemd subsystem allows a grace period for services to shutdown before they are forcefully terminated. However, if your system overwrites configured shutdown times, it may interfere with a graceful shutdown.For example, on AWS, the platform can force terminate a VM after two minutes. As such, the services must be shut down manually as a node drain can take up to 5 minutes (this is a requirement of a graceful shutdown). | If the shutdown process is not forceful, the node should reboot without any issues. |
| Forcefully terminating a server node. | Not applicable. | In most cases the node will start up, but there may be problems with some services that use persistent data. Although these issues are typically recoverable, setting up backups is strongly recommended. The insights pod will not restart until the original node is back online, in order to prevent potential data loss. If the node is not recoverable, contact the support team. |
Shutdown behavior
During shutdown, systemd stops the services in the order they were started. Since the node-drain service has the After=rke2-server.service or After=rke2-agent.service directive, it executes its shutdown sequence before the rke2-service shutdown. This means that, in a properly configured system, simply gracefully shutting down the node is a safe operation.
Manual restart
If you plan to stop the rke2 service and reboot the machine, take the following steps:
To ensure that the cluster is healthy while performing node maintenance activity, you must drain the workloads running on that node to other nodes. To drain the node, run the following command:
systemctl stop node-drain.servicesystemctl stop node-drain.service -
Stop the Kubernetes process on the node, depending on the node type:
- On a server node:
systemctl stop rke2-serversystemctl stop rke2-server - On an agent node:
systemctl stop rke2-agentsystemctl stop rke2-agent
- On a server node:
Terminate the rke2 services and containerd and all child processes:
rke2-killall.shrke2-killall.sh
To download rke2-killall.sh script, refer to Installation packages download links.
Startup behavior
The rke2-service starts and is followed by node-drainer and node-uncordon. node-drainer does not do any action at startup, just returns confirmation that the service is up.
The node-uncordon only runs once and starts /opt/node-drain.sh nodestart, which uncordons the node. As part of the drain procedure that occurs at shutdown, this cordons the node, making it unschedulable. This state persists when the rke2 service starts. As such, the node must be uncordoned after rke2-service restarts.
Manual startup
The service starts automatically with Automation Suite. However, if rke2-service was manually stopped, you must start the service again by running the following commands:
Start the Kubernetes process on the node, depending on the node type:
- On a server node:
systemctl start rke2-serversystemctl start rke2-server - On an agent node:
systemctl start rke2-agentsystemctl start rke2-agent
- On a server node:
Once the
rke2service is started, uncordon the node to ensure Kubernetes can now schedule workloads on this node:systemctl restart node-uncordonsystemctl restart node-uncordon -
Once the node is started, you must drain the node:
systemctl start node-drain.servicesystemctl start node-drain.serviceImportant:Skipping this step could cause the Kubelet service to shut down in an unhealthy way if the system is restarted.
Patching cluster nodes
When patching or restarting server nodes, the order in which you apply changes directly affects cluster stability.
Pre-patch checks
Before touching any node, confirm the cluster is healthy:
Confirm all three etcd members are healthy:
ETCD_CONTAINER="$(/var/lib/rancher/rke2/bin/crictl ps --name etcd --state Running -q | head -n1)" /var/lib/rancher/rke2/bin/crictl exec "$ETCD_CONTAINER" etcdctl \ --endpoints=https://127.0.0.1:2379 \ --cacert=/var/lib/rancher/rke2/server/tls/etcd/server-ca.crt \ --cert=/var/lib/rancher/rke2/server/tls/etcd/server-client.crt \ --key=/var/lib/rancher/rke2/server/tls/etcd/server-client.key \ endpoint health --clusterETCD_CONTAINER="$(/var/lib/rancher/rke2/bin/crictl ps --name etcd --state Running -q | head -n1)" /var/lib/rancher/rke2/bin/crictl exec "$ETCD_CONTAINER" etcdctl \ --endpoints=https://127.0.0.1:2379 \ --cacert=/var/lib/rancher/rke2/server/tls/etcd/server-ca.crt \ --cert=/var/lib/rancher/rke2/server/tls/etcd/server-client.crt \ --key=/var/lib/rancher/rke2/server/tls/etcd/server-client.key \ endpoint health --cluster -
Check for crash-loops on any node:
journalctl -u rke2-server --since "2 hours ago" | grep -i "FAILURE\|left-over\|unclean"journalctl -u rke2-server --since "2 hours ago" | grep -i "FAILURE\|left-over\|unclean" -
Verify a recent etcd snapshot exists:
ls -lth /var/lib/rancher/rke2/server/db/snapshots/ | head -5ls -lth /var/lib/rancher/rke2/server/db/snapshots/ | head -5
Do not start patching if any node is already crash-looping or if etcd health checks fail. Resolve the instability before proceeding.
Identify the bootstrap node
The bootstrap node is typically the current etcd leader. To identify it, run the following command and look for IS LEADER: true:
endpoint status --cluster
Patch order
Always patch the bootstrap node first, then secondary nodes one at a time.
Patching the bootstrap node first ensures that when it goes down, the two secondary nodes maintain quorum and elect a new leader. The bootstrap node then rejoins as a follower in a clean state. Patching secondary nodes first and leaving the bootstrap node for last can cause wider instability if the bootstrap node fails to rejoin cleanly.
After each node patches and restarts, confirm it is fully back before proceeding to the next node:
Verify the node status is
Ready:kubectl get nodeskubectl get nodes -
Check for errors in the RKE2 server logs:
journalctl -u rke2-server -n 30journalctl -u rke2-server -n 30
Kernel upgrades
When performing a kernel upgrade, wipe the containerd snapshot store after running rke2-killall.sh and before applying the kernel upgrade. This prevents containerd state corruption on any node, regardless of patch order.
Files created during installation
The following unit files are created during installation:
rke2-server.service(server only) - Starts therke2-server, which starts the server node.rke2-agent.service(agent only) - Starts therke2-agent, which starts the agent node.node-drain.service- Used at shutdown time. Executed before shutting downrke2-agentorrke2-serverand performs a drain. Has a timeout of 300 seconds.node-uncordon.service- Used at startup to uncordon a node.var-lib-kubelet.mount- Autogenerated by fstab generator.var-lib-rancher-rke2-server-db.mount- Autogenerated by fstab generator.var-lib-rancher.mount- Autogenerated by fstab generator.
There are no strong dependencies between the unit files. However, node-drain and node-uncordon have the After=rke2-server.service or After=rke2-agent.service directive. This means that those services will start after the rke2-server.service.
