Unable to connect to AutomationSuite_ProcessMining_Warehouse database using a pyodbc format connection string
Solutions for pyodbc connection failures to Process Mining Warehouse database in Automation Suite.
Possible cause
SQL Server is in the SQL Server Always On Availability Group and a listener is used to route the traffic between data centers.
Possible solution
Remove the listener from the SQL Server Always On Availability Group and make sure to include the SQL Server instance name in the connection string.
  • Possible cause
  • Possible solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
