- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Debug a failed Automation Suite installation by checking node status, logs, and running diagnostic commands.
If the Automation Suite installation fails while running the uipathctl installer, take the following steps to debug it:
Check if the nodes are active.
- For server nodes, run
sudo systemctl status rke2-server. - For agent nodes, run
sudo systemctl status rke2-agent.- If the nodes are active, but the installation failed, use the diagnostic tool to troubleshoot.
- If a node is inactive, check the installation logs for any errors.
Capture basic installation logs.
The installer prints the installation log location when using
uipathctl.Troubleshooting can also be done based on the logs available in ArgoCD, Istio, or on the machine itself. For details, refer to Exploring logs.
Capture all installation logs. To capture all logs related to the Automation Suite installation, download the
rke2logCollector.shscript from GitHub and run it under the root account. The script collects the following data:- system info
- network info
- docker info
- k3s info
- rke2 info
- rancher logs
- k8s component logs
- system pod logs
- nginx-proxy info
- k3s cluster logs
- system pod logs
- rke2 cluster logs
- rke2 system pod logs
- rke2 agent/server logs
- system logs from /var/log
- system logs from journald
- k8s directory state
- k8s certificates
- k3s directory state
- k3s certificates
- k3s server certificates
- rke2 directory state
- rke2 certificates
- rke2 server certificates
- rke etcd info
- etcdctl output
- rke2 etcd info
