How to migrate to cgroup v2
Migrate host nodes from cgroup v1 to cgroup v2 in Automation Suite on Linux.
To migrate your host VM nodes from cgroup v1 to cgroup v2:
  1. Put the cluster in maintenance mode.
  2. Perform the following steps sequentially on every node:
    1. Drain the node:
      kubectl drain <node-name> --ignore-daemonsets --delete-emptydir-data
    2. Enable cgroup v2:
      sudo grubby --update-kernel=ALL --args="systemd.unified_cgroup_hierarchy=1"
    3. Reboot the node.
    4. After the node reboots, verify the migration:
      stat -fc %T /sys/fs/cgroup/
      The command should return cgroup2fs.
    5. Uncordon the node:
      kubectl uncordon <node-name>
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
