Converting an existing installation to multi-site setup
Convert an existing Automation Suite installation into a multi-site setup with primary and secondary clusters.
You can convert an existing installation into multi-site by taking the following steps:
  1. Convert the standalone Automation Suite cluster into the primary cluster. For details, refer to Converting a standalone cluster into a primary cluster.
  2. Install secondary Automation Suite cluster. For details, refer to Disaster Recovery - Installing the secondary cluster.
Note:
Ensure that the certificates are the same on the primary and secondary clusters. This check is not performed or enforced automatically.
To convert an existing Automation Suite cluster into a primary cluster of the multi-site deployment, take the following steps:
  1. Update cluster_config.json. Add or update fqdn, cluster_fqdn, and enable multisite.
    "fqdn" : "<global traffic manager fqdn>"
    "cluster_fqdn": "<fqdn of the primary cluster>",
    "multisite": {
        "enabled": true,
        "primary": true
    "multisite": {
        "enabled": true,
        "primary": true
    For details, refer to: Advanced installation experience. Update the TLS certificate section to configure the new certificate, ensuring it meets the requirements outlined in the Active/Passive Certificate Requirements section.
    Note:
    It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
  2. Configure the infrastructure on the first server node.
    1. Navigate to the installer folder:
      cd /opt/UiPathAutomationSuite/{version}/installer
    2. Run the following command on the first server node:
      ./bin/uipathctl rke2 update-fqdn -i /path/to/cluster_config.json --versions versions.json
      This will update all the other nodes in the cluster, including the remaining server nodes, agent nodes, and specialized agent nodes.
  3. Configure the fabric and services on the first server node, by running the following command:
    ./bin/uipathctl manifest apply cluster_config.json --versions versions.json
  • Converting a standalone cluster into a primary cluster
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
