- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Before starting the Automation Suite Robot installation, make sure you meet the hardware requirements.
In a single-node evaluation installation, Automation Suite Robots run on the main server node. Cached packages are stored on the main node’s filesystem, in a folder that the interactive installer automatically provisions. Adding a dedicated agent node for Automation Suite Robots is optional in single-node evaluation installations.
Note: In a single-node evaluation installation, the number of concurrent serverless jobs is limited to 5. -
In a multi-node HA-ready production environment, adding a dedicated node for Automation Suite Robots is mandatory. For details on the requirements the dedicated node must meet, see Hardware and software requirements.
Note: In a multi-node HA-ready production installation, the maximum number of concurrent serverless jobs is determined by the node’s resources (CPU/memory). - A minimum of 10GiB are required for package caching.
The following sections provide instructions on how to add a dedicated agent node for Automation Suite Robots.
Step 1.1: Partitioning the disk
To ensure the disk is partitioned correctly, see the instructions in Configuring the disk for a multi-node HA-ready production setup. Make sure to follow the steps for agent nodes.
Step 1.2: Configuring the disk for package caching
Option A
/uipath_asrobots_package_cache
location or at the custom path configured via cluster_config.json/packagecachefolder
. The folder must have at least 10GiB of free space available, otherwise the installation will fail.
Option B
configureUiPathDisks
script, which can configure the disk and the path:
~/configureUiPathDisks.sh --node-type agent --robot-package-disk-name [DISKNAME] --robot-package-path [PATH]
parameter is optional. If not set, the parameter defaults to /uipath_asrobots_package_cache
, make sure the value passed to the --robot-package-path
parameter matches the configured value.
Online Installations
To copy the interactive installer to the target machine in an online installation, take the following steps:
Offline Installations
To copy the interactive installer to the target machine in an offline installation, take the following steps:
To configure the dedicated node in an online installation, take the following steps:
To configure the dedicated node in an offline installation, take the following steps:
To set the kubectl context on the Automation Suite Robots machine, run the following command:
sudo su -
export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodes
sudo su -
kubectl get nodes
You should see the nodes and their corresponding names. You need the name of the Automation Suite Robots node for the next step.
<node name>
with the Automation Suite Robots node name.
kubectl describe node <node name> | grep -i "taints"
The command should return the following output:
$ kubectl describe node asrobots0 | grep -i "taints"
Taints: serverless.robot=present:NoSchedule
At this point, you have successfully completed the installation for Automation Suite Robots.
- Requirements
- Adding an Automation Suite Agent Node to the Cluster
- Step 1: Configuring the Machine
- Step 2: Copying the Interactive Installer to the Target Machine
- Step 3: Running the Interactive Installer to Configure the Dedicated Node
- Step 4: Enabling Kubectl
- Step 5: Verifying the Automation Suite Robots Configuration
