Adding a Dedicated Agent Node for Automation Suite Robots
Requirements
Before starting the Automation Suite Robot installation, make sure you meet the hardware requirements.
  • In a single-node evaluation installation, Automation Suite Robots run on the main server node. Cached packages are stored on the main node’s filesystem, in a folder that the interactive installer automatically provisions. Adding a dedicated agent node for Automation Suite Robots is optional in single-node evaluation installations.
    Note: In a single-node evaluation installation, the number of concurrent serverless jobs is limited to 5.
  • In a multi-node HA-ready production environment, adding a dedicated node for Automation Suite Robots is mandatory. For details on the requirements the dedicated node must meet, see Hardware and software requirements.
    Note: In a multi-node HA-ready production installation, the maximum number of concurrent serverless jobs is determined by the node’s resources (CPU/memory).
  • A minimum of 10GB are required for package caching.
Adding an Automation Suite Agent Node to the Cluster
The following sections provide instructions on how to add a dedicated agent node for Automation Suite Robots.
Step 1: Configuring the Machine
Step 1.1: Partitioning the disk
To ensure the disk is partitioned correctly, see the instructions in Configuring the disk for a multi-node HA-ready production setup. Make sure to follow the steps for agent nodes.
Step 1.2: Configuring the disk for package caching
Option A
If you enabled package caching during installation, you must provision a folder on the filesystem of the host machine at the /uipath_asrobots_package_cache location or at the custom path configured via cluster_config.json/packagecachefolder. The folder must have at least 10GB of free space available, otherwise the installation will fail.
Option B
Alternatively, you can provision a separate disk to the configureUiPathDisks script, which can configure the disk and the path:
~/configureUiPathDisks.sh --node-type agent --robot-package-disk-name [DISKNAME] --robot-package-path [PATH]~/configureUiPathDisks.sh --node-type agent --robot-package-disk-name [DISKNAME] --robot-package-path [PATH]
Note:
The --robot-package-path parameter is optional. If not set, the parameter defaults to /uipath_asrobots_package_cache.
If you modify the default value of cluster_config.json/packagecachefolder, make sure the value passed to the --robot-package-path parameter matches the configured value.
Step 2: Copying the Interactive Installer to the Target Machine
Online Installations
To copy the interactive installer to the target machine in an online installation, take the following steps:
  1. SSH to the right machine:
    • If you added Automation Suite Robots to a single-node evaluation installation, go to the main machine.
    • If you added Automation Suite Robots to a multi-node HA-ready production installation, go to any of the server nodes.
  2. Copy the contents of the UiPathAutomationSuite folder to the Automation Suite Robots node. Make sure to use the username and DNS specific to the Automation Suite Robots node.
    sudo su -
    scp -r /opt/UiPathAutomationSuite <username>@<node dns>:/opt/
    scp -r ~/* <username>@<node dns>:/opt/UiPathAutomationSuite/sudo su -
Offline Installations
To copy the interactive installer to the target machine in an offline installation, take the following steps:
  1. SSH to the primary installation node.
  2. Ensure that the UiPathAutomationSuite directory contains the as-infra.tar.gz file. For download instructions, see as-infra.tar.gz.
    scp -r ~/opt/UiPathAutomationSuite <username>@<node dns>:/var/tmpscp -r ~/opt/UiPathAutomationSuite <username>@<node dns>:/var/tmp
Step 3: Running the Interactive Installer to Configure the Dedicated Node
To configure the dedicated node in an online installation, take the following steps:
  1. SSH to the Automation Suite Robots node.
  2. Run the Automation Suite interactive installer.
    sudo su -
    cd /opt/UiPathAutomationSuite
    yum install unzip jq -y
    CONFIG_PATH=/opt/UiPathAutomationSuite/cluster_config.json
    UNATTENDED_ACTION="accept_eula,download_bundle,extract_bundle,join_asrobots" ./installUiPathAS.shsudo su -
To configure the dedicated node in an offline installation, take the following steps:
  2. Install the platform bundle using the following script:
    sudo su
    mv /var/tmp/UiPathAutomationSuite /opt
    sudo chmod -R 755 /opt/UiPathAutomationSuite
    sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j asrobots --offline-bundle ./as-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreementsudo su
Step 4: Enabling Kubectl
To set the kubectl context on the Automation Suite Robots machine, run the following command:
sudo su -
export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodessudo su -
kubectl get nodes
You should see the nodes and their corresponding names. You need the name of the Automation Suite Robots node for the next step.
Step 5: Verifying the Automation Suite Robots Configuration
Check if the Automation Suite Robots node is configured. Make sure to replace <node name> with the Automation Suite Robots node name.
kubectl describe node <node name> | grep -i "taints"kubectl describe node <node name> | grep -i "taints"
The command should return the following output:
$ kubectl describe node asrobots0 | grep -i "taints"
Taints:             serverless.robot=present:NoSchedule$ kubectl describe node asrobots0 | grep -i "taints"
At this point, you have successfully completed the installation for Automation Suite Robots.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
