Endpunkte in gutem Zustand
Um den Zustand Ihrer Automation Suite-Dienste effektiv zu überwachen, können Sie die in diesem Abschnitt aufgeführten Zustandsendpunkte verwenden. Mit diesen Endpunkten können Sie schnell überprüfen, ob ein Dienst ordnungsgemäß funktioniert.
Plattform
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupproxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
AI Center
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
  • https://<automation-suite-fqdn>/insights_/health
Benachrichtigungsdienst
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robotub
  • https://<automation-suite-fqdn>/robotube_/healthz
Task Mining
  • https://<automation-suite-fqdn>/taskmining_/console/api/health
  • https://<automation-suite-fqdn>/taskmining_/storage/api/health
Test Manager
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Überprüfen des Dienstzustands
Um den Zustand eines bestimmten Dienstes zu überprüfen, senden Sie eine Anforderung an den entsprechenden Endpunkt, wie im folgenden Beispiel gezeigt.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
Eine erfolgreiche Antwort mit einem HTTP-Statuscode 200 zeigt an, dass sich der Dienst in einem guten Zustand befindet.
Verbinden
Benötigen Sie Hilfe? Support
