Letzte Aktualisierung 13. Nov. 2025
Datenträger kann nicht verbunden werden und verbleibt im Status der „Attach/Detach“-Schleife
Beschreibung
Aufgrund eines Longhorn-Fehlers führt die Racebedingung zu einer Expansion der Replikatgröße. Um zu überprüfen, ob das Volume dieses Problem aufweist, suchen Sie nach dem folgenden Fehler in den Longhorn-Manager-Protokollen:
 --  9776:2023-10-12T00:17:01.290911721Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Creating volume pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25 controller with iSCSI target request timeout 15s and engine to replica(s) timeout 8s" 9777:2023-10-12T00:17:01.298832774Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Starting with replicas [\"tcp://10.42.2.132:10015\"]" 9780:2023-10-12T00:17:01.322556233Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=warning msg="Backend tcp://10.42.2.132:10015 size does not match 3221225472 != 16106127360 in the engine initiation phase" 9782:2023-10-12T00:17:01.330974089Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=error msg="no available backend due to replica error from the addresses [tcp://10.42.2.132:10015]"  --- --  9776:2023-10-12T00:17:01.290911721Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Creating volume pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25 controller with iSCSI target request timeout 15s and engine to replica(s) timeout 8s" 9777:2023-10-12T00:17:01.298832774Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Starting with replicas [\"tcp://10.42.2.132:10015\"]" 9780:2023-10-12T00:17:01.322556233Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=warning msg="Backend tcp://10.42.2.132:10015 size does not match 3221225472 != 16106127360 in the engine initiation phase" 9782:2023-10-12T00:17:01.330974089Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=error msg="no available backend due to replica error from the addresses [tcp://10.42.2.132:10015]"  ---
Alternativ können Sie überprüfen, ob das Volume auf der Longhorn-Benutzeroberfläche im Expansionsstatus angezeigt wird.
Lösung
Führen Sie die folgenden Schritte aus, um dieses Problem zu beheben:
  1. Verkleinern Sie den Anwendungs-/Workload-Pod.
  2. Erweitern Sie den PVC auf die Größe des Replikats.
  3. Vergrößern Sie den Anwendungs-/Workload-Pod.
  • Beschreibung
  • Lösung
Hilfe erhalten
UiPath Community-Forum
Vertrauen und Sicherheit
© 2005–2025 UiPath. Alle Rechte vorbehalten
