2022.4
Single-node upgrade fails at the fabric stage
When upgrading single-node deployments with in-cluster storage from version 2022.4.1 or older, the upgrade script fails at the fabric stage due to a rook-ceph migration issue.
The issue occurs when upgrading to any version between 2022.4.2 and 2022.4.9.
Solution
To fix the issue, run the following command before starting the upgrade:
Important: Make sure you execute the command only on single-node deployments. Running the command on multi-node deployments will disable data redundancy.
function set_config_ceph_pool_all(){
  local config_name="$1"
  local config_value="$2"
  local pool_name
  for pool_name in $(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool ls); do
    kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool set "${pool_name}" "${config_name}" "${config_value}"  || true
  done
# set pool size to 1 for all the pools
set_config_ceph_pool_all "size" "1"
# set pool min size to 1 for all the pools
set_config_ceph_pool_all "min_size" "1"function set_config_ceph_pool_all(){
  local pool_name
  done
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
