2022.4
Last updated Mar 17, 2025
Additional configuration
Repaving or Updating the NFS Server
Important:
UiPath does not provide any specific steps to repave or update the NFS server.
Before updating the NFS server, make sure the backup is disabled. For instructions, see Disabling the backup on the cluster.
Guidelines
It is good practice to back up the disk attached to the NFS server where you create the backup. You can find this information defined as the nfs.mountpoint key in the backup.json file.
To repave the NFS server, take the following steps:
  1. Mount the backup disk on the newly repaved machine on the same mount point as defined by the nfs.mountpoint key in the backup.json file.
  2. Update the NFS endpoint of the new NFS server defined as nfs.endpoint in backup.json.
  3. After repaving the NFS server, make sure you have followed the Setting up the external NFS server guidance.
Once the update to NFS server is complete, it is recommended to reboot the machine. Also make sure to enable the backup on cluster. For instructions, see Manual: Enabling the backup on the cluster.
Adding a New Node to the Cluster
To add a new node to the cluster, re-run the following steps:
  1. Add the FQDN or the IP address of the new node to the allowlist of the NFS server. For instructions, see Allowing NFS mount path access to all backup and restore nodes.
  2. Enable the backup on the new node post-installation. For instructions, see Enabling the backup on remaining server nodes of the cluster.
  • Repaving or Updating the NFS Server
  • Guidelines
  • Adding a New Node to the Cluster
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
