- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
This section covers exporting POD logs. For exporting robot logs, see Ochestrator - About Logs.
Splunk is an external tool, and UiPath does not have an opinion on how you should configure your Splunk setting. For more details about HTTP Event Collector, see Splunk official documentation.
The Splunk-Fluentd stack is a centralized logging solution that allows you to search, analyze, and visualize log data. Fluentd collects and sends the logs to Splunk. Splunk retrieves the logs and lets you visualize and analyze the data.
To create a secret in the cluster with Splunk's HTTP Event Collector token, run the following command:
kubectl -n cattle-logging-system create secret generic splunk-hec-token --from-literal=splunk_hec_token=<splunk_hec_token>kubectl -n cattle-logging-system create secret generic splunk-hec-token --from-literal=splunk_hec_token=<splunk_hec_token>Run the following command to ClusterOutput to Splunk. Replace the following attributes with the ones used in your Splunk configuration:
kubectl -n cattle-logging-system apply -f - <<"EOF"
apiVersion: logging.banzaicloud.io/v1beta1
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey: <splunk_hec_timekey>
timekey_use_utc: true
timekey_wait: 10s
type: file
hec_host: <splunk_hec_host>
hec_port: <splunk_hec_port>
hec_token:
valueFrom:
secretKeyRef:
key: <secret_key>
index: <splunk_hec_index>
insecure_ssl: true
protocol: <splunk_hec_protocol>
source: <splunk_hec_source>
sourcetype: <splunk_hec_source_type>
EOFkubectl -n cattle-logging-system apply -f - <<"EOF"
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey_wait: 10s
type: file
hec_token:
valueFrom:
secretKeyRef:
key: <secret_key>
insecure_ssl: true
EOF|
Attribute |
Description |
The network host of your Splunk instance. |
The Splunk port for client communication. |
The secret key with the Splunk token. |
splunk_hec_timekey value in splunkHec.buffer |
The output frequency, i.e., how often you want to push logs. |
The URL protocol. Valid values are
http and https.
Identifier for the Splunk index to be used for indexing events. |
The source field for events. |
The source type field for events. |
Run the following command to ClusterFlow in Fluentd:
kind: ClusterFlow
metadata:
namespace: cattle-logging-system
spec:
filters:
- tag_normaliser:
format: ${namespace_name}/${pod_name}.${container_name}
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- aicenter-hit-count-update
- istio-configure-executor
- on-prem-tenant-license-update
- curl
- recovery
- aicenter-oob-scheduler
- cert-trustor
- exclude:
namespaces:
- fleet-system
- cattle-gatekeeper-system
- default
- exclude:
labels:
app: csi-snapshotter
- exclude:
labels:
longhorn.io/job-task: backup
- exclude:
labels:
app: csi-resizer
- select: {}
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- curl
- recovery
- cert-trustor
- exclude:
namespaces:
- fleet-system
- default
- exclude:
labels:
- exclude:
labels:
- exclude:
labels:
app: csi-resizer
- select: {}
EOFClusterOutput.
If for some reason the application logs are not getting pushed to Splunk, try the following:
- Change the Fluentd log level to debug
Query the Fluentd pod:
kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n cattle-logging-system exec -it sts/rancher-logging-root-fluentd cat /fluentd/log/outkubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n cattle-logging-system exec -it sts/rancher-logging-root-fluentd cat /fluentd/log/outNote: The Fluentd logs should indicate the cause of data not being pushed to Splunk. -
After you fix the issue, restore the FluentD log level:
kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel"}]'kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel"}]'
