2022.4
Last updated Mar 17, 2025
Failure to create persistent volumes
Longhorn is successfully installed, but fails to create persistent volumes.
Solution
Verify if the kernel modules are successfully loaded in the cluster by using the command lsmod | grep <module_name>.
Replace <module_name> with each of the following kernel modules:
  • libiscsi_tcp
  • libiscsi
  • iscsi_tcp
  • scsi_transport_iscsi
Load any missing module.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
