2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Performing node operations
| Documentation | Description |
| Adding a new node to the cluster | How to scale your deployment by adding additional nodes. |
| Removing a node from the cluster | How to safely remove a node from the cluster on a multi-node HA-ready production setup. |
| Repaving a cluster node | How to repave cluster nodes without any risks. |
| Shutting down a node | How to perform a graceful node shutdown. |
| Renaming a node | Best practices for renaming nodes. |
| Performing node maintenance | What to do before and after a node maintenance operation, to ensure the cluster is healthy. |
Important:
RHEL kernel versions kernel-4.18.0-372.91.1.el8_6 and kernel-4.18.0-477.10.1.el8_8 are affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses these kernel versions either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libs
