2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
You need to have a resource group under your Azure subscription for running Automation Suite. If you want to use an existing one, you can skip this step and specify the resource group in the later steps.
- Go to the Azure portal.
- Search for Virtual Network from the home page and select Create.
All the machines that we provision should be part of this virtual network
- Type virtual machines in the search field.
- Under Services, select Virtual machines.
- In the Virtual machines page, select Create. The Create a virtual machine page opens.
Basics Tab
You can configure the VM directly during the creation step under the Disks tab.
Important: Each machine needs to be added to the virtual network. For both single-node evaluation deployments or a multi-node HA-ready
production deployments, you need to create the virtual network. Each Azure VM resides in a Virtual Network (private network)
and the public IP is the way by which we are exposing it to external connections (internet).
Follow these steps to create a new Virtual Network (or select the existing one) and Public IP address:
