2022.4
AWS deployment parameters
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
Important:
The Template-hosting S3 Region parameter must match exactly the AWS region in which you try to deploy. If the region does not match, the deployment does not succeed.
Keep the default settings for the parameters labeled Quick Start S3 bucket name, Quick Start S3 bucket Region, and Quick Start S3 key prefix. If these input parameters are altered, the deployment does not succeed.
Table 1. Availability Zone Configuration
Parameter label (name)
Template
Default value
Availability Zones
  • New VPC
  • New VPC, in-depth configurable
Requires input
Choose up to three Availability Zones to use for the VPC subnets.
Number of Availability Zones
  • New VPC
  • Existing VPC
2
Choose the number of Availability Zones to use in the VPC.
For a new VPC, this must match the number you set using the Availability Zones parameter.
For an existing VPC, you can set two or three Availability Zones.
Deploy Bastion host
  • Existing VPC
Deploy a Bastion host inside the public subnet.
Table 2. Network configuration
Template
Default value
VPC CIDR
  • Existing VPC
10.0.0.0/16
VPC CIDR block. Example: x.y.0.0/16, x.y.z.0/24.
VPC ID
  • Existing VPC
Requires Input
ID of the existing VPC.
Public subnet IDs
  • Existing VPC
Blank string
List of public subnet IDs where the internet-facing Load Balancer and the Bastion host will be deployed.
Private subnet IDs
  • Existing VPC
Requires Input
List of private subnet IDs.
Table 3. Automation Suite Instance Configuration
Template
Default value
Instance key pair
  • New VPC
  • Existing VPC
Requires input
Existing key pair to connect to virtual machine (VM) instances.
Instance AMI id
  • Existing VPC
Blank string
AMI ID to use for the creation of the EC2 instances of the cluster.
When the AMI ID is not specified, the default version deployed is RHEL 8.3 for non GPU VM and RHEL 8.2 for GPU VM.
GPU instance AMI id
  • Existing VPC
Blank string
AMI ID to use for the creation of the GPU-enabled EC2 instance.
IAM Role ARN
  • Existing VPC
Blank string
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment.
IAM Role name
  • Existing VPC
Blank string
Name of a pre-deployed IAM Role with sufficient permissions for the deployment
Table 4. Automation Suite Deployment Configuration
Template
Default value
Deployment Type
  • New VPC
  • Existing VPC
Single Node
Install Automation Suite in single-node evaluation mode or multi-node HA-ready production mode.
Enable cluster backup
  • New VPC – backup is enabled by default but not exposed as a parameter
  • Existing VPC
Enable the cluster backup.
Load Balancer
  • New VPC
  • Existing VPC
ALB
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you must configure the TLS certificates manually post deployment.
Perform Installation
  • Existing VPC
Perform the Automation Suite installation.
Automation Suite Version
  • New VPC
  • Existing VPC
e.g. 22.4.0
Automation Suite version to install.
Automation Suite Product Selection
  • New VPC
Default platform
Choose Default platform to install Orchestrator, Action Center, Test Manager, Insights, Automation Hub, Automation Ops.
Choose Entire platform to additionally install Apps, AI Center, Task Mining, Document Understanding.
Installer download URL
  • Existing VPC
Blank string
Custom URL for installer download. Leave empty to use the UiPath version.
Add GPU enabled VMs
  • New VPC
  • Existing VPC
falseChoose true to add a GPU-enabled VM to the deployment.
Extra configuration keys
  • Existing VPC
Blank string
Extra configuration keys to add to the cluster configuration.
Validity of the self signed certificate
  • Existing VPC
1825
Validity, in days, of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC.
Table 5. Automation Suite Services
Template
Default value
Service install flags
(multiple)
  • Existing VPC
Choose if a specific service is installed in the cluster.
Table 6. DNS or SSL Configuration
Templates
Default value
Hosting FQDN
  • New VPC
  • Existing VPC
Requires input
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the of ID of Route 53 hosted zone parameter.
  • New VPC
  • Existing VPC
Requires input
ID of the Route 53-hosted zone.
ARN of the ACM hosted certificate to use
  • Existing VPC
Blank string
ARN of the certificate present in the ACM (Amazon Certificate Manager) to use with the ALB.
Use Internal Load Balancer
  • Existing VPC
Choose if you want to use an internal load balancer.
Table 7. RDS Configuration
Template
Default value
Engine of SQL Server deployed on RDS
  • Existing VPC
sqlserver-se
Choose the RDS Microsoft SQL engine.
Version of SQL Server deployed on RDS
  • Existing VPC
15.00
Choose the RDS Microsoft SQL version.
KMS Key Id used to encrypt RDS storage
  • Existing VPC
Blank string
KMS Key ID to use for the encryption of the RDS storage.
Table 8. Quick Start S3 bucket configuration
Parameter label (name)TemplateDefault valueDescription
Template folder
  • New VPC
  • Existing VPC
aws-quickstart-sf-v2022-4-5/
You must not change the value.
  • New VPC
  • Existing VPC
us-east-1
Must match the region where you deploy the resources in AWS. For example, if you want to deploy in us-east-1, select us-east-1.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
