2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Occasionally, the ArgoCD UI does not show pods, but only displays applications and corresponding deployments. See the following image for details:
When selecting on any of the deployments, the following error is displayed:
Unable to load data: EOF.
You can fix this issue by deleting all Redis replicas from ArgoCD namespace and waiting for it to come back up again.
kubectl -n argocd delete pod argocd-redis-ha-server-0 argocd-redis-ha-server-1 argocd-redis-ha-server-2
# Wait for all 3 pods to come back up
kubectl -n argocd get pods | grep argocd-redis-ha-serverkubectl -n argocd delete pod argocd-redis-ha-server-0 argocd-redis-ha-server-1 argocd-redis-ha-server-2
