2022.4
Last updated Mar 17, 2025
Migrating from Canal to Cilium CNI
Important:
  • This step is only required when performing a manual upgrade from Automation Suite 2021.10.
  • To reduce the time required for a Canal to Cilium migration, you can skip the prerequisite check when running install-uipath.sh using the -- skip-pre-reqs parameter.
Online
To migrate from Canal to Cilium, take the following steps on all the machines in the cluster. Make sure to perform this operation on one node at a time.
  1. To migrate, run the following command:
    ./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --accept-license-agreement./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --accept-license-agreement
  2. Reboot the node using the reboot command or any other safe reboot method you may prefer.
Offline
To migrate Canal to Cilium, take the following steps on all the machines in the cluster. Make sure to perform this operation on one node at a time.
    ./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --offline-bundle ../sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --accept-license-agreement./install-uipath.sh --upgrade -c -i ./cluster_config.json -o ./output.json --offline-bundle ../sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --accept-license-agreement
  • Online
  • Offline
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
