- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
On top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For more details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
Use |
CPU |
RAM (GiB) |
GPU |
Disk (GiB) |
Minimum for serving (ML Skill, one replica) |
0.6 |
2 |
0 |
Minimum for Training (Pipeline) |
1 |
4 |
0 |
DU model Serving (ML Skill, one replica) |
1 |
4 |
0 |
DU model Training |
2 |
24 |
Strongly recommended |
Use |
CPU |
RAM (GiB) |
GPU |
Disk (GiB) |
Small implementation:
4 |
32 |
0 |
Average implementation:
8 |
52 |
rancher partition = 80 GiB on the rancher partition
2 1 pipeline * 105GiB = 105 Data disk
rancher partition = 160 GiB on the rancher partition
4 (2 pipeline + 1 DU pipeline) * 105GiB = 315 Data disk
