2022.4
How to clear Redis data
To clear all the data stored in Redis and reset it to an empty state, take the following steps:
  1. Identify the secret name, password, and port:
    export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"; export PATH=$PATH:/var/lib/rancher/rke2/bin;
    secretName=$(kubectl get redb redis-cluster-db -o jsonpath="{.spec.databaseSecretName}" -n redis-system)
    password=$(kubectl get secret $secretName -o jsonpath="{.data.password}" -n redis-system | base64 --decode)
    port=$(kubectl get secret $secretName -o jsonpath="{.data.port}" -n redis-system | base64 --decode)export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"; export PATH=$PATH:/var/lib/rancher/rke2/bin;
  2. Identify the service names:
    kubectl get secret $secretName -o jsonpath="{.data.service_names}" -n redis-system | base64 --decodekubectl get secret $secretName -o jsonpath="{.data.service_names}" -n redis-system | base64 --decode
  3. Let's assume the output of the previous command is: redis-cluster-db, redis-cluster-db-headless. You must call the following FLUSHALL commands:
    kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db -p $port -a $password FLUSHALL
    kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db-headless -p $port -a $password FLUSHALLkubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db -p $port -a $password FLUSHALL
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
