2022.4
- Overview
- Automation Suite overview
- Responsibility matrix
- Glossary
- Automation Suite Products
- Cross-product Dependencies
- Deployment architecture
- Supported use cases for single-node and multi-node installations
- Cross-deployment Feature Comparison
- Certificates overview
- Requirements
- Hardware and software requirements
- Evaluating Your Storage Needs
- Estimating Cloud Infrastructure Costs
- Capacity Planning
- Using uipathctl.sh
- AI Center considerations
- Root privileges requirements
- High Availability – three availability zones
- Certificate Requirements
- Network Requirements
- Validating the prerequisites
- Validating the Prerequisites in a Single-node Evaluation Setup
- Validating the Prerequisites in a Multi-node HA-ready Production Setup
- Q&A: Deployment Templates
- Recommended: AWS Deployment Template
- Release Notes
- AWS deployment architecture
- Step 1: Preparing the AWS deployment
- Step 2: Deploying the Quick Start template
- Step 3: Post-deployment steps
- AWS deployment parameters
- Roles and policies
- Recommended: GCP Deployment Template
- Release Notes
- GCP Deployment Architecture
- Step 1: Preparing the GCP Deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment Steps
- Recommended: Azure Deployment Template
- Release notes
- Azure deployment architecture
- Step 1: Preparing the Azure deployment
- Step 2: Deploying Automation Suite to Azure
- Manual: Single-node evaluation profile requirements and installation
- Configuring the Machines
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the Certificates
- Online Single-node Evaluation Installation
- Offline Single-node Evaluation Installation
- Manual: Multi-node HA-ready production profile requirements and installation
- Configuring the load balancer
- Online multi-node HA-ready production installation
- Offline Multi-node HA-ready Production Installation
- Manual: Advanced Installation Experience
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-on for the Cluster
- Document Understanding configuration file
- Adding a Dedicated Agent Node With GPU Support
- Sample Azure Infrastructure Setup
- Step 1.1: Creating the VM
- Step 1.2: Configuring the VM
- Step 2: Configuring the Load Balancer
- Step 3: Configuring Azure SQL
- Step 4: Configuring the DNS
- Accessing Automation Suite
- Managing the Certificates
- Resizing PVC
- Updating the SQL connection strings
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Backing up and restoring the cluster
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Performing node operations
- Adding a New Node to the Cluster
- Removing a Node From the Cluster
- Repaving a cluster node
- Starting and shutting down a node
- Renaming a node
- Performing node maintenance
- Optimizing Objectstore Storage
- Manual: Migrating Ceph Data Pool From Replicated to Erasure-coded Type
- Automated: Migrating Ceph Data Pool From Replicated to Erasure-coded Type
- Configuring the cluster
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Setting up Splunk
- Monitoring and alerting
- Using the monitoring stack
- Alert Runbooks
- Migration and upgrade
- Upgrading Automation Suite
- Automated: Online upgrade
- Automated: Offline upgrade
- Manual: Online upgrade
- Manual: Offline upgrade
- Rollback on Error
- Migrating Longhorn physical disk to LVM
- Migrating from Canal to Cilium CNI
- Downgrading Ceph From 16.2.6 to 15.2.9
- Migration options
- A) Full migration
- Migration prerequisites
- Compatibility matrix
- Pre-migration steps
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- Migration steps
- Post-migration steps
- Step 1: Removing old Identity cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Clearing Redis data
- Step 4: Validating the Insights migration
- B) Single tenant migration
- Apps
- Audit Logs Queries
- MongoDB Monitoring Dashboard
- MongoDB Certificate Renewal
- Access to the Models
- Insights
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring Log Rules
- Orchestrator
- Migrating standalone Orchestrator to Automation Suite
- Preparing Orchestrator
- Updating the Orchestrator configuration
- Using the Orchestrator Configurator Tool
- Task Mining
- Out-of-sync Task Mining
- Cleaning up the Task Mining database
- Installation best practices
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- Troubleshooting
- How to
- How to clear Redis data
- How to enable Istio logging
- Installation and configuration troubleshooting
- RKE2 fails during installation and upgrade
- Upgrade and migration troubleshooting
- SQL validation fails during upgrade
- Storage troubleshooting
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- Authentication troubleshooting
- ArgoCD login failed
- Node maintenance troubleshooting
- Node Draining Does Not Occur for Stopped Nodes
- Rke2-coredns-rke2-coredns-autoscaler Pod in CrashLoopBackOff
- Other troubleshooting
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Orchestrator troubleshooting
- Orchestrator Pod in CrashLoopBackOff or 1/2 Running With Multiple Restarts
- Test Manager troubleshooting
- Test Manager licensing issue
- AI Center troubleshooting
- AI Center skills deployment issues
- Unknown error when accessing AI Center
- Enabling AI Center on the restored cluster
- Document Understanding troubleshooting
- Document Understanding Not on the Left Rail of Automation Suite
- Failed Status When Creating a Data Labeling Session
- Failed Status When Trying to Deploy an ML Skill
- Migration Job Fails in ArgoCD
- Handwriting Recognition With Intelligent Form Extractor Not Working
- Insights troubleshooting
- Navigating to Insights homepage generates a 404
- Looker fails to initialize
- Exploring Logs
Last updated Mar 17, 2025
This log could be found when using Kerberos for SQL access, and SQL connection is failing inside services. Similarly, you
may see
kinit: Client's credentials have been revoked while getting initial credential in one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
