- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
This page explains what certificate configuration entails at the time of installation.
The installation process generates self-signed certificates on your behalf. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
Aside from the above certificates, you may need to provide additional trusted CA certificates if you want the cluster to trust external services. Example: SQL Server CA Certificate, SMTP Server CA Certificate, etc.
The installation bundle provides a cluster management tool that enables you to update certificates post-installation.
To access it, navigate to the location of the installer bundle:
cd /opt/UiPathAutomationSuite/cd /opt/UiPathAutomationSuite/For instructions on updating the certificates, see Managing certificates.
If you are using a self-signed certificate, take the following steps to access the cluster:
You need to add CA (Certificate Authority) Bundle certificate to the trust store for the following:
- Client machine
- Machine on which robot will run.
- Machine on which you will access Automation Suite from the browser.
- First server machine (requirement for air-gapped)
- Machine on which air-gapped bundle will be downloaded and extracted.
Use the following command to add the certificate to the trust store of the RHEL machine.
sudo cp --remove-destination rootCA.crt /etc/pki/ca-trust/source/anchors/
sudo update-ca-trustsudo cp --remove-destination rootCA.crt /etc/pki/ca-trust/source/anchors/
