- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Manual: Migrating Ceph Data Pool From Replicated to Erasure-coded Type
- Automated: Migrating Ceph Data Pool From Replicated to Erasure-coded Type
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
To reduce the Objectstore storage requirements for the HA deployment model, you can migrate Ceph data pool from replicated type to erasure-coded type.
In versions prior to 2022.4, Ceph was using the replicated type of data pool, which takes 900 GiB of space across the cluster to store 50 GiB of objects. The erasure-coded pool will reduce the storage space required to store the same 50 GiB objects from 900 GiB to 450 GiB.
To migrate Ceph data pool from the replicated to erasure-coded type, take the following steps:
The script will perform the pre-migration checks to verify if the Ceph cluster is healthy and supported for the migration, and will only then perform the actual migration.
Insufficient Storage space available for LH node error, and it is not possible to increase the storage space, you can perform the manual migration using Rados Export/Import.
For instructions, see Manual: Migrating Ceph data pool from replicated to erasure-coded type.
