2022.4
AWS deployment architecture
Architecture diagram
Complete component list
Entry Points
  • Main stack – principal entry point:
    • Network stack
    • Uipath-sf stack
  • In-depth configurable stack:
    • Network stack
    • Uipath-sf stack
  • Uipath-sf stack
Nested Stacks
  • Uipath-sf:
    • SSL stack
    • Routing stack
    • Server stack
    • Database stack
    • Backup stack
    • Management stack
    • Lambda functions (AWS::Lambda::Function):
      • FindAMIFunction – for finding a matching AMI Id.
      • CreateInputJsonFunction – for creating the configuration used by the Automation Suite installer.
      • ComputeResourceSizeFunction – for computing the minimum EC2 instances hardware configuration needed, based on the selected services and deployment type.
    • IAM roles (AWS::IAM::Role) for the Lamdda functions to provide minimum permissions:
      • FindAmiLambdaRole
      • CreateInputJsonLambdaRole
      • ComputeResourceSizeLambdaRole
    • Secrets (AWS::SecretsManager::Secret) to store sensitive information:
      • RDSPassword
      • OrgSecret
      • PlatformSecret
      • ArgoCdSecret
      • ArgoCdUserSecret
      • InputJsonSecret
      • KubeconfigSecret
    • SSL Stack (optional)
  • Network stack (optional)
  • Backup stack (optional):
    • ClusterBackupStorage (AWS::EFS::FileSystem) – Amazon Elastic File System used to store the backup.
    • SharedStorageSecurityGroup (AWS::EC2::SecurityGroup) – Security group used to allow NFS network connections from the cluster nodes.
    • SharedStorageMountTargetOne (AWS::EFS::MountTarget) – Resource that creates the mount target for the EFS file system and the first private subnet.
    • SharedStorageMountTargetTwo (AWS::EFS::MountTarget) – Resource that creates the mount target for the EFS file system and the second private subnet.
    • SharedStorageMountTargetThree (AWS::EFS::MountTarget) – Optional resource that creates the mount target for the EFS file system and the third private subnet.
  • Database stack:
    • RDSDBInstance (AWS::RDS::DBInstance) – The Amazon RDS DB instance. The DB SKU is db.m5.2xlarge.
    • DBSubnetGroup (AWS::RDS::DBSubnetGroup) – Private subnet group that contains the private subnets.
    • DbSecurityGroup (AWS::EC2::SecurityGroup) – Security Group allowing access to the DB instance.
  • Routing stack:NOTE: The Alb and Nlb stacks are mutually exclusive configurations
    • Alb stack:
      • ExternalLoadBalancer (AWS::ElasticLoadBalancingV2::LoadBalancer) – Application load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.
      • ELBSecurityGroup (AWS::EC2::SecurityGroup) – The security group applied to the load balancer.
      • HttpsTargetGroup (AWS::ElasticLoadBalancingV2::TargetGroup) – The target group of the load balancer.
      • HttpsListener (AWS::ElasticLoadBalancingV2::Listener) – The listener for the load balancer.
    • Nlb stack:
      • ExternalLoadBalancer (AWS::ElasticLoadBalancingV2::LoadBalancer) – Network load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.
      • TcpTargetGroup (AWS::ElasticLoadBalancingV2::TargetGroup) – The target group of the load balancer.
      • TcpListener (AWS::ElasticLoadBalancingV2::Listener) – The listener for the load balancer.
    • KubeLoadBalancer (AWS::ElasticLoadBalancingV2::LoadBalancer) – Private network load balancer used for node registration.
    • KubeApiTcpTargetGroup (AWS::ElasticLoadBalancingV2::TargetGroup) – The target group for the node registration traffic of the KubeLoadBalancer.
    • KubeApiTcpListener (AWS::ElasticLoadBalancingV2::Listener) – The listener for the node registration traffic of the KubeLoadBalancer.
    • Rke2RegistrationTcpTargetGroup (AWS::ElasticLoadBalancingV2::TargetGroup) – The target group for the node registration traffic of the KubeLoadBalancer.
    • Rke2RegistrationTcpListener (AWS::ElasticLoadBalancingV2::Listener) – The listener for the node registration traffic of the KubeLoadBalancer.
    • RootRecordSet (AWS::Route53::RecordSet) – DNS A record for the FQDN.
    • SubdomainRecordSet (AWS::Route53::RecordSet) – DNS A record for the subdomains of the FQDN.
  • Management stack:
    • LifecycleAutomationLogs (AWS::Logs::LogGroup) – Log group for logging events from the SSM automation.
    • SSM Documents (AWS::SSM::Document) sets of steps used to provide graceful node removal:
      • ServerRemoveInstanceDocument
      • AgentRemoveInstanceDocument
      • UpdateAMIDocument – Updates the AMI ID for the Auto Scaling Groups.
    • Autoscaling Lyfecycle hooks (AWS::AutoScaling::LifecycleHook) that allow us to run the SSM documents when an EC2 instance receives an instance termination event:
      • ServerAsgLifeCycleHookTerminating
      • AgentAsgLifeCycleHookTerminating
    • Event rules (AWS::Events::Rule) that trigger the execution of the SSM Documents:
      • ServerTerminateEventRule
      • AgentTerminateEventRule
    • IAM roles (AWS::IAM::Role) needed for running SSM Documents and adding logs to the Log Group:
      • AutomationAssumeRole
      • EventsBridgeAssumeRole
    • Server stack:
    • ServerLaunchConfiguration (AWS::EC2::LaunchTemplate) – EC2 instance configuration for the server nodes. Disk configuration:
      • OS disk – sku gp2, capacity 128GiB
      • Cluster disk – sku gp2, capacity 300GiB
      • etcd disk – sku io1, capacity 32GiB
      • Data disk – sku gp2, capacity 512GiB or 2TiB depending on the selected services.
    • AgentLaunchConfiguration (AWS::EC2::LaunchTemplate) – EC2 instance configuration for the agent nodes. Disk configuration:
    • GpuEnabledNode (AWS::EC2::Instance) – Optional GPU node. It has the same disk configuration as an agent.
    • TaskMiningNode (AWS::EC2::Instance) - Optional Task Mining node. Deployed only if the Task Mining service is selected. It has the same disk configuration as an agent.
    • BastionHost (AWS::EC2::Instance) – Optional EC2 instance used to SSH to cluster nodes. It has the t3.large instance type and a 200GiB gp2 disk.
    • ServerAutoScalingGroup (AWS::AutoScaling::AutoScalingGroup) – Auto scaling group for the servers.
    • AgentAutoScalingGroup (AWS::AutoScaling::AutoScalingGroup) – Auto scaling group for the agents
    • Optional ServiceFabricIamRole (AWS::IAM::Role) that has permissions to:
      • write logs
      • read EC2 instances configurations
      • download AWS Quickstart resources
      • access the Automation Suite installation configuration secret
      • access the cluster kubeconfig configuration secret
    • ServiceFabricSecurityGroup (AWS::EC2::SecurityGroup) – Security Group allowing access to UiPath applications.
    • BastionSecurityGroup (AWS::EC2::SecurityGroup) – Optional Security Group allowing SSH access to Bastion
    • AsgProcessModifierFunction (AWS::Lambda::Function) – Used to modify the ASG processes during CF stack creation.
    • AsgProcessModificationRole (AWS::IAM::Role) – IAM role to provide minimum permissions for the AsgProcessModifierFunction
    • SSM parameters (AWS::SSM::Parameter):
      • InstanceAMIIdSSMParameter – Stores the AMI ID of the nodes.
      • InstanceAMIImageNameSSMParameter – Holds the Image Name used at deployment time or updated via the UpdateAMIDocument.
    • Autoscaling Lyfecycle hooks (AWS::AutoScaling::LifecycleHook) that allow us to transition EC2 instances to InService state after the installer succeeded:
      • ServerAsgLifeCycleHookLaunching
      • AgentAsgLifeCycleHookLaunching
Deployment and Instance Type Mapping
The template dynamically computes the hardware needed for the deployment as follows:
  • Depending on the services installed (basic or complete product selection), it sets minimum requirements at cluster level.
  • Depending on the deployment profile (multi-node or single-node profile), it sets minimum requirements for a single VM.
  • Selects the instance types based on their availability in the region you deploy and the aforementioned requirements.
The following table shows the mappings between deployment and possible instance types:
Deployment type
Instance types
Basic single-node
c5.4xlarge, c5a.4xlarge, m5.4xlarge, m5a.4xlarge
Complete single-node
c5a.8xlarge, c5.9xlarge, m5.8xlarge
Basic multi-node
c5.4xlarge, c5a.4xlarge, m5.4xlarge, m4.4xlarge
Complete multi-node
c5a.8xlarge, c5.9xlarge, m5.8xlarge, m5a.8xlarge
  • Architecture diagram
  • Complete component list
  • Entry Points
  • Nested Stacks
  • Deployment and Instance Type Mapping
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
